First Resin Model | FerrariChat
First Resin Model
Discussion in 'Collectables, Literature, & Models' started by Vito, May 17, 2008.
  1. Vito
    Vito Formula Junior
    485
    Dutchess County, NY
    I recently acquired the 1/43 BBR kit of the Ferrari 250 LM (1965 LeMans winner). However, this will be the first resin model kit that I've assembled. I've done plenty of plastic and metal kits, and have expereince in painting and assembling them. Are there any particular tricks or issues that I should know about before undertaking this resin kit? How does the painting and finishing of a resin kit differ from that for a plastic or metal kit? I appreciate your comments and suggestions.
  2. F1tommy
    F1tommy F1 World Champ
    11,584
    Sugar Grove USA
    Tom Tanner
    Hi,
    You have to clean and prime resin before you paint as the mold releases
    have oil. The window frames will be tricky if you are new to this .You can use
    non fogging super glue. Another option is Formula 560 modelers glue with Tamiya tape to hold until it dries. I like to cut the frame from the tree and carefully glue to the clear sheet, then trim around the frame shape, without touching the glass. The hardest part is making them fit(the 250LM windshield has alot of curve).
    TT/SD
  3. desire308
    desire308 Formula 3
    Oct 19, 2007
    1,433
    Florida
    Peter W
    #3 desire308, May 17, 2008
    1] Clean the resin parts with Exacto knife, files and 600 grit wet/dry sandpaper.
    2] Soak in very warm soapy water for a few hours. A bit of laundry detergent will help remove the mold release. Scrub down with soapy water and rinse. Repeat until the surface "drags" and is not slippery.
    3] Prime with a good rattle can primer. I use Dupli Color grey primer from an auto parts store. Let dry a few hours and wet sand w/1000 or 1500 grit.
    4] paint with either Tamiya laquer or rattle can colors from an auto paint store [they can get it into the rattle can for you].
    5] decal
    6] prime and paint the interior and base
    7] lay out the clear accetate for the windows on a very clean, dry surface. Take the photo etch frames and using painters tape as "tabs" tack them down in four corners. Using a good set of small scissors trim the outside of the accetate from the frames. Using a good, clear epoxy contact cement run a bead of glue around the inside of the frame and set in place. Using additional tape tabs tack it in place. Let it dry completely and then run a very light bead of clear cement around the edge of the glass and this will seal the glass to the frame. Remove the tape when dry and fill the gaps. If the lower corners want to lift use a very small pick and some super glue to tack it down. DO NOT use super glue to install these windows!!! Using this method will allow tollerance for the glass and photo etch so it won't bind during installation.
    Complete assembly using super glue and white glues [for the pe parts].
    Don't worry...relax!
    Feel free to contact me via email if you have any questions...I am glad to help. I have been building these for a very long time.
    This model incorporated these tecniques...
  4. Vito
    Vito Formula Junior
    485
    Dutchess County, NY
    to Desire308 - Thank you for the infomration. I won't be starting the resin model right away but when I do I will certainly contact you for suggestions & commnets as I proceed.
