First single & dual channel A/F runs with LM-2 | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by snj5, Aug 9, 2008.
  1. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Yeah it is but you put it anywhere near a plug wire and it's not . .. scope it and see.
  2. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    Does the new unit have any internal accelerometers? Nice to see how she actually pulls . . think you're carrying an extra few hundred pounds in the Mondi vs the 308 but she might keep up with my car (on the straight) ;) . . . don't bother trying to go 'round corners fast and pulling close to the "g" my 308 is capable of . . . you might hurt somebody ;)
    Totally teasing . . . one of these days I need an F car with a back seat . .. actually no I don't . . I removed my passenger seat for a while ;)
  3. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    And with EFI it stays that way during hard cornering :)
  4. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    #29 KKRace, Aug 12, 2008
    Not unless you add the AUX box which has two axis Accels built in. Also does not have any GPS utils at all which would be nice. Tempted to get rid of the LM2 and replace it with an LC1 and a Datalogger unit with gps. It would be real nice to see what it's doing on different sections of track.
    Someone mention additional inputs. Besides being able to handle 1 or 2 O2 sensors it has 5 analog inputs and 2 programable analog outputs standard. You can get more inputs by adding the aux box or some other moduals they make.
  5. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    they are such fun toys!!! . . . that's a good way to go with a seperate data logger . . the only thing I dislike about the LM1 is the unit doesn't work when the o2 sensor dies. :(
    I'm not sure which data logger to go with . . . you thinking about Innovate's latest product? . . . the problems you guys are having with their latest products isn't a good thing though.
    BTW you know there's an application for IPOD/IPhone that measures G forces? . . it's like $15-20 . . . I'll get more infoo if anyone needs it . .. P club guys have been playing with it.
    Cheers,
    Sean
  6. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    this is the Innovate product? . . .and you use LC1's for O2 which just output 0-5v signal which work with any data logger?
    What's the price so all the info is here in one place? . . . that's great that it works with the auxbox and hopefully it doesn't need the o2 input to function . . that'd be stupid if they did that.
  7. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    The only stand alone unit I see at Innovate is the DL32 for $500 which has all the sensors built in inside .. . just makes my auxbox obsolete.
    The unit you're referring to perhaps requires a computer for data logging?
  8. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I'd be interested in what you consider 'way lean', and under what circumstances. :)
    I'm actually tuning the Webers throughout the band (why I got the LM-2) but concentrating on four places: idle mixture, throttle response, cruise/transition, and WOT. The last set-up was really good with WOT at 13 and cruise at 14.
    Don't worry about upsetting me with your video - I'm glad you like your F1 sounds because I think modern F1s sound like poo. Show me what you got, junior. :)
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    yes - us carb guys use a device called an accellerator pump. :)
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    The MSD 6AL box is in the trunk, with a firewall between it and the coil, so I am not expecting any intefererence. As I said, it's probably close enough for what I want to do so this may work out.
    I am calling Innovate to see if they have an extension for the right side sensor so as to enable dual A/F, although for what I am doing, one may be just fine. As Lee would tell you, I am using these numbers for sure, but still a lot comes from sound and feel. MAP would be nice, but I think I can jet around it.
  11. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    They do have an extension.
    For someone else that asked the single channel LM2 is $475 and the dual is about $150 more.
  12. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    http://www.race-technology.com/dl1_8_936.html
    Here is the GPS data logger I was refering to. $965 plus the cost of the LC1 if you want O2 without a real time display
    One of my complaints with the LM2 was it was very hard to read the display to tell if you started recording or not. Did they fix this on your new unit? If your holding it in your hand it's not too bad but when you mount it to the dash in a racecar it was really hard to see if there was a little "R" in the black background text in the bottom left of the screen.
  13. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    In the racecar I have the MSD mounted in the passenger compartment and the coil is in the engine bay with the spark plug wires. Don't know what the problem is? I might have it too close to the cable that comes from the msd to the coil?
  14. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    didn't know those helped for cornering :)
    there was an offensive video I posted with a guy lighting up the tires like it wasn't his car ... that car sounds exactly like mine :)
    bummer you don't like new F1 cars mate . .. definitely stick with carbs then :)
    way lean is 14.7 and higher at every point except full throttle . . I could say it's a green thing but it's not :) . . tons of info about tuning on the Innovate site . . give those guys a chance .. its a bummer your unit isn't giving you clean data right out of the chute.
    I wish I could just "jet my way" out of all problems in life (inside joke to myself ;)).
    cheers,
    adrinkie
  15. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    sucks you guys are having issues with these units . . their forum is awesome and the owner answers questions (haven't been on there for 1 year though so who knows???) . . I do recall when I bought my unit the "new products" they were introducing were having a lot of issues but they were all over it on their forum.
    no affiliation . . etc.
    cheers
  16. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    #41 KKRace, Aug 12, 2008
    Keep it below 12 WOT. Probably not losing too much HP if any at 12, but remember you are measuring an average not each cylinder and just like the two sides are reading different, each hole is different. If you are getting 13 or higher WOT there is a good chance one hole maybe reading 12.7 and another might be 13.4 to give you the 13 reading. Also temp, air density etc. You don't want to go out on a cool day and roach the motor. Keep a very close eye on the plugs and check for any signs of lean often if you are going to run anything over a 12 a/f ratio. You will need at least a 10x mag to look to see if you are getting little aluminum balls on the plugs.
    The a/f will affect water temp quite a bit. Keep a close eye on the gauges on warm days if you are going to try to run over 12 A/F. I see most guys running 12.5 to 13 on the dyno and then throwing extra jet at the engine when they put it in the car since the key word in racing is "Dynamics" , nothing is staying the same and one thing effects the other. You might get an extra 1 or 2 hp running a little leaner but the extra heat might make it so the cooling system can't do it's job and you lose hp and damage the motor.
  17. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    carb problem only :)
    edit: EFI guys make more power on these days
  18. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    To be accurate, depends what kind of EFI vs how the carbs were set up; don't throw out generalities and give folks the wrong idea... :)
  19. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I would agree to keep it in the 12s WOT, especially if compression is bumped. It has also been my experience that V-8 Ferraris tend to like mixtures a bit rich and as long as you are above 12 you are within a few (3-8 or so) hp of max looking at dynos. Its quite do-able to jet a WOT of 12 with a steady cruise of 13 or so off throttle. What is interesting is I have seen perfectly tuned K-jet cars by the book dyno from 3000 to redline solidly holding 14.2 all the way up.
    thanks all for the discussion!
  20. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #45 luckydynes, Aug 13, 2008
    The aux box and several other Innovate products have thermocouple inputs on them . . isn't measuring exhaust gas temperature one of the ways you look for optimum a/f ratio besides dyno? I wanted to play with this but figured a thermocouple on the outside of the header wouldn't be accurate enough . . .thoughts? Omega has a screw in thermocouple but wrapping a wire thermocouple around the outside of the header sure is easy . .. but if the data's no good what's the point.
    Russ did you see a difference front to rear bank or did you have an air leak? Can't remember if I saw the front bank richer or leaner and can trim the injectors if necessary.
    Thanks,
    Sean
  21. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    curious . . .which EFI doesn't? I've never messed with one that doesn't look or compensate for air temp whether it's thru mass density or pressure density calculation.
    also . . . I'm not a carb guru by any scretch . . I don't think accel pumps are there to facilitate hard cornering . .. when you're in the middle of a high speed turn at the limit your right foot isn't gonna do anything that the accel pump is gonna care about if you catch my drift (hey no pun intended) :).
    carbs are inferior . . there I said it ;).
  22. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    The richness difference did not isolate to a bank; the richness difference isolated to the O2 sensors, and minimizes at higher flows, so for trimming above idle I think we're ok. As KKRace said, there can be differences with how the injectors sit in the stream. The air leak is a good Idea, and would also minimize with higher flow, but the fact that the difference follows the injectors (unless an injector has a leak) kind of narrows it down.
    EGT is the most common way that aircraft lean to best mixture at cruise, but is done at steady state under fixed conditions.
  23. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #48 snj5, Aug 13, 2008
    I never said they weren't - but depending on the set up they can deliver more air/fuel and make more hp - and the engine doesn't care what delivers. For example, eight 40mm carb throats can deliver more air than one 65mm throttle body - it's just physics. EFI is much more flexible under different load conditions, but max hp is all about who gets the most air in.
    It's just fun pushing your button, as there is some insecurity there. :)
    The subtlety of the accel pump comment was you should be accellerating through and out of the curve, and the pump keeps the mixture stable in the power range.
  24. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    of course there is . . . looking at your car makes me want Webers but I have to keep telling myself NO NO NO :)
    my only experience with tuning accel pumps is with Holleys and a big block going in a straight line . .. that was enough for me . . I keep telling myself ;)
    cheers Russ . . all in the name of improving these girls!
  25. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    see shows what I know . . I thought the accel pump was to compensate for the sudden drop in manifold pressure when you instantly open the throttle . . . which is something you do not do at or near the cornering limits of a car.
