First start after 6 months | FerrariChat
Discussion in '612/599' started by gsholz, May 16, 2024.
  1. gsholz
    gsholz Formula Junior
    347
    Oregon
    Jerry
    My car was hibernating the last 6 months. What is the best way to build oil pressure before the engine starts? I don't think the 599 has a "clear flood" mode. Do I pull the fuel pump fuse? Other ideas?
  2. tazandjan
    39,164
    Not sure if the 599 is the same as the 575M, but if you do not disarm the immobilizer, she will turn over, but not start on the 575M. Same for the 599?
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,905
    Central NJ
    Dominick
    You can pull the fuel pump relays .. but remember if you turned the key with the relays in there and later pull the relays ..you will still have pressure and the car will start and try to run
    The best is to pull the relays and let sit overnight if you turned the key on recently
    Skidkid likes this.
  4. gsholz
    347
    Oregon
    Jerry
    flash32 likes this.
