360 - First start after winter hibernation | FerrariChat
360 First start after winter hibernation
Discussion in '360/430' started by MartinM.no, Feb 24, 2024.
  1. MartinM.no
    MartinM.no Rookie
    Aug 27, 2018
    44
    Oslo Norway
    Martin Myhre
    Hello
    First winter with the 360 in the garage is finally coming to an end. I am planning to start the car and change the oils and, brake fluid, shock bushes and brake pads.
    Car has not been started during winter. Do you start the car right up or do you pull some fuses to build oil pressure?
    I live in Norway so car has been stored in cold temperature, and it is still 0-6 degrees here.
    Martin
  2. swc5150
    swc5150 Formula Junior
    725
    Wisconsin
    Scott Calderwood
    I turn the key the "on" position for maybe 30 seconds, then it fires right up from hibernation. Got my car out 3 weeks ago:)
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,927
    Central NJ
    Dominick
    Never hurts to pull fuel pump fuses before you turn key the first time ..if you already turned key the pressure is there ..will have to pull ignition fuse
    Or just don't disarm immo
  4. Qavion
    Qavion F1 World Champ
    14,290
    Ian Riddell
    There are no fuel pump fuses on the F360, Dominick ;) I think the Motronic Sx & Motronic Dx fuses* might do the same job, but your "don't disarm immo" suggestion sounds good (on an F1 car). Or pull the fuel pump relays on a gated car (or the Motronic Sx/Dx fuses*).
    * these fuses remove battery power from the fuel pump relays and the Motronic ECUs.
  5. MartinM.no
    MartinM.no Rookie
    Aug 27, 2018
    44
    Oslo Norway
    Martin Myhre
    Thanks for response. Try the immo trick.
    Br Martin
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,927
    Central NJ
    Dominick
    #6 flash32, Feb 25, 2024
    I would yes and no .. I consider the f60 fuse one of them .. :)
    But I normally, when I do this on any car, i just pull the relays before turning key
    Thanks for clarification
    Qavion likes this.
  7. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    361
    Do we need to cut the battery (so we don't fry anything) before we remove the pump relays on a gated car?
  8. Qavion
    14,290
    Ian Riddell
    If the ignition is not on, there will be no current flowing through the relay. There is live battery power on one contact of the relay socket, but it's not like you could short it to anything easily.
    Some Guy in the sky likes this.
  9. Some Guy in the sky
    Sep 19, 2018
    361
    Thanks, better to ask than just give it a go and fry thousands of dollars worth of ancient electronics.
