First Track Day in the F355: Impressions | Page 2 | FerrariChat
Discussion in '348/355' started by MK355, Jun 10, 2024.
  1. MK355
    MK355 Karting
    184
    M K
    The B-G Racing Spacer is PCD so should work, correct?
    "Multi-drilled for both 6x70mm and 6x74mm PCD bolt patterns to accommodate the majority of aftermarket steering wheels, enabling cross compatibility between hub kits and steering wheels with either 6x70mm or 6x74mm PCD patterns."
  2. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
    #27 ShineKen, Jun 13, 2024
    That works for the PCD to the Momo steering wheel. The PCD on the car side is unique to the 355.
    The B-G setup looks like an extension to an adapter. You want something that is an adapter and extension at the same time. Just makes things easier.
  3. ShineKen
    20,202
    Southern California
    Nostradamus
    355 is a 4 bolt adapter. Don’t know what the PCD is, but unlikely an adapter will work unless specified it will work with a 355.
    MK355 likes this.
  4. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,958
    Richmond
    Pete
    What's the hole spacing on the 355 (4 hole)? I think it might work without another adapter if you don't mind it being not perfectly centered (which won't be noticeable if offset vertically).
