First wax application after repaint | FerrariChat
Discussion in 'Technical Q&A' started by f1_nix, Oct 4, 2007.
  1. f1_nix
    f1_nix Formula 3
    2,212
    Ft. Worth, TX
    This may belong in the dumb question thread but here goes...
    Recently had my car repainted and need to apply its first coat of wax. Other than carefully washing and drying the car are there any special considerations I need to worry about?
    Thanks. Sorry if it's a dumb question.
  2. Llenroc
    Llenroc F1 Veteran
    5,550
    Colorado
    Vern
    They used to say wait 30 days but that was the old paint days prior to the base coat clear coat paints of today. I would think that you should be able do to it sooner but not certain, there must be a paint gut out there somewhere.
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,828
    Cerritos, CA.
    How recent?
  4. islandguy
    islandguy Formula 3
    1,439
    Northern CA & NV
    Actually this is a great question, and the right time to ask. What ever you do choose your product system carefully. You are in an excellent position to use a synthetic like Zaino. There are many threads here on the subject. Good Luck.
  5. OC Speed Junkie
    OC Speed Junkie Formula 3
    Aug 6, 2005
    2,473
    Southern California
    Joseph
    Call who ever painted your car and ask them. I have heard times from min of 30 days to 6 months from different painters shooting different paint. 30 days is bare minimum.
  6. Motob
    Motob Formula 3
    Nov 11, 2003
    2,389
    Frederick, Maryland
    Brian Brown
    New paint takes a long time to cure. Applying wax to the surface will seal it and not allow the solvents in the paint to evaporate, slowing/stopping the curing process. After our paint shop paints a car, they wet sand the entire surface to remove the cured outer surface, this allows the solvents to out-gas quicker. Then the paint is allow to dry for many weeks/months before it is finally polished.
    I would talk to the painter, find out what kind of paint was used and talk to a rep. from the paint manufacturer before applying any type of wax/glaze/polish to the new paint.
    Brian B.
  7. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    The days of paint curing over a period of months are behind us. The EPA made regulations changing that so that solvents weren't evaporating from your new paint into the air. You may try using a body shop safe glaze like 3M's imperial hand glaze. As long as it's body shop safe you won't have any problems (not that you should on todays paints anyway). This way you can scratch the itch to wax and keep your mind at ease then in a few months add whatever carnuba or polymer based product you like.
    http://www.autogeek.net/3mimhanglaz.html
  8. Todd Helme
    Todd Helme Formula Junior
    Apr 2, 2007
    947
    Oviedo Florida
    Todd Helme
    This is true to an extent. Your best bet is to contact your painter. It still needs to outgas. That is the solvents used to make your paint flow (even though they are EPA complient) still need to outgas to allow the paint to fully harden and to avoid problems in the future. Your painter may have baked the body, in which case the paint would be fully outgassed.
    You can use a glaze, which only offers mild protection (as mentioned in the post I quoted) for a couple of days. Meguiars #5 is a very easy to use glaze. Talk to your painter first.
  9. h00kem
    h00kem Guest
    Dec 15, 2004
    734
    Texas
    Ask the painter how long you should wait (also ask what kind of wax he recommends for the heck of it). He is the one who will be asked to stand behind it if the wax job turns out to be done too soon!
  10. f1_nix
    f1_nix Formula 3
    2,212
    Ft. Worth, TX
    The paint job was completed mid-July. I believe it was a ureathane base coat and clear coat, but I'm not completely sure. I will double check with the paint shop
    In the past I have used the Best in Show Wax from Griot's Garage with good results. Aside from a gentle washing/drying beforehand, are there any other prep steps I need to perform?
  11. f355spider
    f355spider F1 World Champ
    18,055
    I would agree with this advice. I had a Ferrari that had the nose/hood repainted...it was perfect when I got it...but over the course of four months, as the paint cured, it developed a mild case of "orange peel". Painter said "no problem"....took it back and he quickly masked it, block sanded and buffed to perfection. He said the paint can continue to "shrink" as it out gases, even though it was thoroughly dried with lamps prior to being originally delivered to me. This was only 5 or 6 years ago, so he used currently available Glasurit paint.
  12. 350HPMondial
    350HPMondial F1 Veteran
    5,333
    Edwardo
    Afetr a repaint, I use Maguire’s #7 only,,,, for first year....
  13. ClydeM
    ClydeM F1 World Champ
    12,059
    Wayne, NJ
    Clyde E. McMurdy
    Mine was just done with Glassurit & a clear-coat. The shop said I should wait a minimum of 10 days. But 30 would be better
