Fitting A 348 Speedometer. | FerrariChat
Discussion in 'Technical Q&A' started by Organiser, Apr 26, 2005.
  1. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Hi all,
    I need to change the KPH speedo in my Spider for a MPH version, can anyone tell me how to remove it from the instrument cluster!!
    Thanks in advance.
    Regards,
    Phil.
  2. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,273
    MA
    Phil, from my poor memory. Remove 2 screws located under the dash; these hold the instrument cluster in place. Carefully tilt the entire cluster up away from the screws and lift up. The top is locked in place by a flat hook and pocket. Mark and unplug the various connections behind the cluster. Once free remove cluster. If I recall correctly you have to remove the center gauge assembly and then the speedometer. Just a few sheetmetal type screws. Install your new instrument and you are home free. Good luck, John.
  3. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    #3 Ferrari_tech, Apr 26, 2005
    Phil,
    This might help.............
  4. Organiser
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    John, Malcolm,
    That`s just the information I needed, thanks very much.
    Another job for the bank holiday weekend now.
    Regards,
    Phil.
  5. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Why? I just spent $300 having the MPH speedo for my Boxer re-silk screened in KPH. I wanted the speedo to match the odometer since it was already in Kms.
  6. Organiser
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Hi,
    The car has never been registered in the UK, it is an Italian spec car that was exported to the Middle East and to use it in the UK it has to have a speedo that reads in MPH not KPH otherwise it will not pass an MOT here.
    Regards,
    Phil.
  7. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    it will pass a mot with a km speedo
  8. 348er
    348er Rookie
    Jun 2, 2023
    7
    sydney australia
    andrew colantuono
    im looking for a KPH speedo for a 1990 348ts can anyone help me out
  9. Manuel.G
    Manuel.G Karting
    Mar 21, 2013
    211
    España - Madrid
    I need one too…
