Fixed It - Backfire, Misfire, Rough Running 348tb | FerrariChat
Discussion in '348/355' started by foxnick348, May 24, 2008.
  1. foxnick348
    foxnick348 Karting
    Nov 22, 2007
    56
    Racine, Wisconsin
    Nick Fox
    Hey All,
    RE: 1992 Ferrari 348TB
    Just wanted to give an update that I fixed my recent Rough-Running and 5-8 bank engine cut-out issues.
    My car was back-firing and popping and hesitating at 4000-5000 rpms and the 5-8 check engine light was coming on and off.
    After researching all of the articles on this board I determined the most common problem would be the speed/crank sensor or connection to the sensor.
    This weekend I jacked up the car and removed the bat shield to reveal the speed sensors just below the main belts.
    Sure enough, I pealed back the rubber boot on the 5-8 bank speed/crank sensor and the wires were seperating and barely hanging on, thus causing the misfire and check engine light to come on when the sensor wiring would short out.
    As a temporary fix I resoldered the wiring into the connector plug until I can hopefully track down a new wiring harness.
    Started her up and she redlines smooth as could be now.
    Hope this helps anyone out there with the same problem.
    This message board is awesome as I now feel more confident owning and working on this Ferrari with the help of others going through the same problems.
    I don't remember all the posts I used to diagnose the problem, but many thaks to all!!!!!!!!
    Nick
    Racine, Wisconsin
  2. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Way to go Nick!! I've owned my '92 TS since January, and haven't had to troubleshoot any problems yet, but I agree with you that this forum is a GREAT resource!! Thanks to all those who help make it so great! :cool: :) Oh, and welcome to Fchat, Nick... your post also helps others!
