Fixing a Ruptured Bore in my Weber Carb. | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by gcmerak, Dec 26, 2009.
  1. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    I would go in a different direction...
    Since it is a 308 carb(yes), I would buy one for 3-400 bucks and rebuild it...???
    If it were a Sand cast, 40 DCN1 where there are no spares AND NO parts either, and the car won't run with out it, then extraordinary efforts are required...
    I would bore/hone the body out, and sleeve it to the closest original bore size I could, finish hone it to size, re-shaft and re-butterfly plate it and replace ALL of the lead plugs, you will have to chase the progression holes for burrs...and perhaps make caps inorder to obatain proper access..small compromise in the bigger picture I think??
    To "do it right", as we all like to quip...requires that you do all 4, and then double check performance gas flow capacities with a flow bench-with out this steep, the ENTIRE exercise, is a waste of your time, and otherwise considerable efforts, and obvious skills....
  2. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    960
    Arizona
    Jim
    The Nov Dec 2009 copy of The Home Shop Machinist magazine has a brief write up on Oxy Acetylene soldering aluminum. Kent White is the author, he is well known for his metal working. He does not mention preheating the metal before soldering it. He recommends cleaning the hell out of it with 70% isopropyl alcohol and a stainless steel toothbrush. For soldering 0.050 inch aluminum he recommends a number 1 tip with the inner cone two metal thicknesses and a feather of two inner cones. He also cautions against overheating it, the solders and flux are heat sensitive.
    Good luck, and keep us posted.
    Cheers Jim
  3. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,665
    Engine Bay, Georgia
    George C.
    I just talked to the technical support gentleman at Eastwood regarding the anti-heat compound. He assured me that this compound is rated to absorb/dissipate up to 3000F. Additionally, he said that this compound is perfectly suited to my carburetor application. It's ordered and on the way.
    Ciao,
    George
  4. staatsof
    96,433
    Fuggetaboutitland
    Bob
    So George,
    I read in one of the threads what sounds like you're going to fix this hole with the idle circuit screw in place and hope to avoid machining this afterwards because the repair material won't stick to the idle screw tip???
    I know I must be nuts thinking this is what you meant??? Of course I'm nuts regardless ...
    Bob S.
  5. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,665
    Engine Bay, Georgia
    George C.
    That's a big 10-4 good buddy!
    Ciao,
    George
  6. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,665
    Engine Bay, Georgia
    George C.
    #31 gcmerak, Dec 30, 2009
    OK. So here is a picture.
    Ciao,
    George
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I see the white rectangle, what's the big blurry thing? ;)
  8. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,665
    Engine Bay, Georgia
    George C.
    #33 gcmerak, Dec 30, 2009
    The big blurry thing is the 4mm hole by George. I'll have better pictures later.
    Ciao,
    George
  9. staatsof
    96,433
    Fuggetaboutitland
    Bob
    I sure hope that "shakin' hands" photographer isn't the one doing the delicate welding ... ;>)
  10. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,665
    Engine Bay, Georgia
    George C.
    #35 gcmerak, Jan 2, 2010
    Hopefully this is a little clearer.
    Ciao,
    George
  11. gcmerak
    gcmerak Formula 3
    Mar 17, 2008
    1,665
    Engine Bay, Georgia
    George C.
    #36 gcmerak, Jan 13, 2010
    Still working on it. Somehow the surface is not being prepped corectly by me.
    For the time being here is a shot I took with a magnifying glass. Ah, yes the magic of optics.
    As a side note, I tried to replicate that kind of a rupture on my practice carb. No matter how hard I tried to turn the idle screw past the stop point, I could not. Now, I can't help but wonder if the carburetor was somehow compromised from a previous fire?
    Ciao,
    George
  12. MiuraP400
    Feb 3, 2008
    960
    Arizona
    Jim
    Thanks for the update, I was wondering if you had any luck with it.
    cheers Jim
  13. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    A couple people have mentioned heat sinks. Aluminum is a heat sink and anything you do to remove heat from one part of the carb will also take it away from the area your trying to heat up. Especially true when using a gas torch vs something like a tig torch.
    My first inclination would be to find a way to machine out the area and press some sort of plug in place. It doesn't look like it's going to be easy from the pics
  14. staatsof
    96,433
    Fuggetaboutitland
    Bob
  15. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    The link didn't really seem to go into any detail? The more thought I give it I still think drilling out the threads and all, reaming to size and pressing an aluminum plug into place and then drilling and taping the plug as the factory did in the original cast piece is the way to go. Probably heat the carb up before attempting to press in the plug in an oven.
