Fixing the 308 Oil Pressure Gauge so that it Reads Accurately | FerrariChat
Discussion in '308/328' started by Brian A, Oct 7, 2014.
  1. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,148
    SanFrancisco BayArea
    1983 US 308 GTS QV
    The above quote is from another thread I started yesterday.
    Has anyone ever successfully fixed their oil pressure gauge system so that it accurately indicates actual oil pressure? Is it the sender that is crappy? The wiring and connectors? Grounding? The gauge itself?
    I take solace in the fact that the 308 oil pump almost never fails but, if I got a gauge, I want it to be accurate. And, it's the most important gauge in the instrument cluster.
  2. George Vosburgh
    George Vosburgh F1 Rookie
    This is on my list for this winter, I'll let you know what I learn.
  3. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I looked into replacing my electronic gauge with the guts of a mechanical. Two issues: no reverse reading gauges available except Smiths and none go 0-170 lbs. seems 100-110 is max. Ended that project. If anyone is aware of a possible please post it.
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    Frankly, the only thing I would do if I was concerned is attach a mech gauge and do some comparisons at different RPM and just take note of it. As long as the e-guage needle moves consistently, it doesn't matter where it points, you can simply be aware that, for example, when the mech gauge indicates 85 PSI, the e-gauge points to wherever it points. Same thing at, say 30 PSI.
    As noted, the gauge in the car is clearly not much of an oil pressure gauge! But if it's calibrated against a mech gauge and you know where the needle points at the highest and lowest acceptable operational pressure readings, it's all you really need in order to know that the pressure is OK.
    Obviously, if you need to know precise pressure for some reason, a different gauge would have to be fitted. The one in the car, even if it was absolutely accurate, doesn't have the necessary indices to do you much good in telling you that at X rpm there is 53PSI, for example.
    FWIW, any oil pressure above 10psi/1000 RPM is a waste of engine power... ;)
  5. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,871
    Mike 996
    All auto oil pumps have a relief valve so as to not blow the system (primarily the oil filter but also any related coolers/hoses, etc)) apart as the pressure rises with RPM. Some - like the 3x8's - have externally adjustable relief valves. All it consists of is a spring which is compressed more or less by some sort of screw fitting. As noted, all the relief valve does is set the maximum pressure that the pump can deliver. Changing its setting has no effect on the accuracy of the gauge.
  7. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,148
    1983 US 308 GTS QV
    No, no, no ... we need accuracy for the sake of accuracy! It doesn't matter that the e-gauge hardly has any meaningful markings on it. :)
    (... and I suspect my gauge doesn't even move consistently: when the engine gets hot it reads lower at the same pressure.)
    BTW, where is the best place to thread a mechanical gauge into the engine?
  8. tomd308
    tomd308 Karting
    Jun 10, 2006
    159
    gainesville florida
    thomas dukas
    I don't know why, but mine reads higher when the headlights are on.
  9. Rifledriver
    37,089
    #9 Rifledriver, Oct 9, 2014
    There are several problems. One is being a electric gauge its reading is based on voltage. The difference between a predetermined "Correct" system voltage and the voltage to the instrument modulated by a variable resistor in the form of an oil pressure sender. Well the voltage source to the instrumments through the relay panel is anything but consistant. Next the senders themselves are terrible pieces of crap and no two seem to work the same. Finally out of frustration a few years ago we sent gauge and sender to a really good instrument shop (not the one in N California so many seem to love) and had the instrument calibrated to a different brand of sender and then rewred the power source to a large B+ buss that had more stable voltage. It worked pretty well. I still prefer a mechanical and expect to get the OE face installed on a quality mechanical on my own at some point.
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    The OEM instruments are for entertainment and amusement only.
    Andreas Engesvik likes this.
  11. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Rather than a mechanical oil pressure gauge on the motor I plugged my sender into pressurized air with a good gauge and regulator. This let me sweep the pressure from 0 to 100 easily. Also I used a voltmeter on the circuit. Turns out the gauge was fairly consistent but the sender was very inconsistent. I opened it and found it full of crud, moisture and corrosion.
  12. dave80gtsi
    dave80gtsi Formula 3
    1,917
    Ohio
    Dave Meredith
  13. George Vosburgh
    Nice thread Dave, thanks for sharing.
  14. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,148
    1983 US 308 GTS QV
    #14 Brian A, Oct 10, 2014
    The VDO gauge conversion thread is very interesting.
    Brian Harper’s 308 sender autopsy confirms what was expected; the sender is using unreliable 50 year old mechanically-actuated technology.
    Does anyone know if new replacement 308 senders are now using solid-state technology or are they still the same old mechanical type like what came with the car? If they are now solid-state, it may be that the problem has already been solved.
    Voltage consistency is a different matter, but the VDO conversion thread makes claim that the VDO system yields stable and accurate pressure measurements despite the voltage problem Rifledriver notes. Surprising, but good to hear. Presumably the Veglia gauge would perform with the same precision if provided with a quality signal.
  15. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    How tough is it to put a a Veglia face on a VDO gauge?
  16. jon s
    jon s Formula Junior
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    i checked the voltage at the fuse box and at the top of the gauge - it's not the problem i have an 81 308 and i think the original sender was replaced with a newer one (? 308 qv). the resistance range is not the same. i measured my oil pressure with a mechanical gauge and it is twice what the veglia gauge reads. you can get the veglia gauge to read correctly if you put a resistance in parallel with the sender but you now only get half the lower scale. i.e. a true pressure of 80 psi will read 80 but zero psi reads 40. i like having all the instrument needles vertical at normal values so i live with the imperfect fix. i bought another sender from mccann but it doesn't have the right resistance range either. if anyone finds a source of senders compatible with the 70's and early 80's cars i'd buy one. jon s
  17. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Sp.uk sells both ranges early and late.
  18. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I don't think it will help us in Ferrariland, but an interesting thing I came across when fixing my old VW Scirocco guages is that they ran them all off of 6V (or some other <12V amount). There was a three terminal regulator to supply a steady DC supply so that even with a low battery or lights on or whatever the gauges were all still accurate.
    OK, not really accurate, but didn't fluctuate with voltage anyway.
  19. jon s
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    crowndog: thanks for that info. i'll check their site today. never hurts to have 3 senders. jon s
  20. jon s
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    crowndog: the 81 308 parts catalog calls for part #114927 but the sp site says that number fits the 308 qv. any experience? jon s - thanks
  21. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Send an email to Ita at SP with exactly what you want and she will get back to you. At least she has always been very helpful to me. Sometimes the website isn't correct or confusing.
  22. jon s
    Mar 9, 2005
    509
    pocasset ma
    jon shoukimas MD
    thanks, i will. jon s
