430 - Flanbloc replacement DYI... anybody? | FerrariChat
430 Flanbloc replacement DYI... anybody?
Discussion in '360/430' started by Mario Andretti, Dec 8, 2022.
  1. Mario Andretti
    Mario Andretti Formula 3
    1,777
    Boston
    Hi,
    Plenty of videos and such for DYI ball joints... but none for flanblocs. Anyone has any good information on what size sockets or bars you need to push them out? I suppose one needs to remove the circlip and inner part before trying to press out.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Just remove the circlip and tap the inner pin out with a plastic or hide hammer, bit of plus gas helps. Dead easy.
  3. Mario Andretti
    1,777
    Boston
    Ok, I did remove the arm and managed to replace them. It is not too hard at all... I will post some instructions and pics tomorrow, including all tools used.
    Cheers.
    colorfull, AandSC and LorenzoR like this.
  4. Mario Andretti
    1,777
    Boston
    ok, here it is:
    1. Remove the upper arm from the car: You need a 13mm socket with an extension and a 10mm ( I think?) hex socket to remove the ball joint screw. Hook up the wheel hub with brake disk and such to the strut with a couple of cable ties so they stay up and don't hang onto wires and stuff. Extension cords might work, but wth. I have plenty of cable ties.
    2. Start your JBL charge 3 or 4 or 5 bluetooth music player so it's more fun in the garage. I recommend Metallica, work will get done faster than say... Shania Twain. And then you can be the Master.
    3. Now that you got that nice aluminum arm get to your bench where you have a vice (you do have one, right? ) and find a 1-7/16 socket (yes, that big) and a 21mm socket.
    4. Before you get cracking, remove the circlip with some circlip pliers (in photo below) and a couple of small screwdrivers to slide it out of the inner part of the flanbloc. We will only press the outer part of the bushing out (pleonasm?) . This is the arrangement I had , and I only needed the 2 sockets and the vice to remove it (see photo below).
    5. One important thing I did; I heated up the arm (bushing section only) with my trusted heat gun, until I smelled burnt rubber. Sign it had enough. Take it slow and don't get too close to the arm. I am not sure how these arms react to sudden heat, I would not care if it was the steel arm in my 335i, I would heat that up to red.
    6. Press them out in the vice, it should not take much effort. Just go slow and make sure the movement is straight, and the sockets lign up, and are parallel and centered to the imaginary line going through the middle of the flanbloc.
    7. If you are an alcoholic like me, have a couple beers, ignoring the fact that it is middle of the day..
    8. Now ,before pushing the new one in, take a 600 - 800 grit sandpaper, and make sure there is no residue or dirt on the inside of the arm. Take it slow and easy and don't over do it , these aluminum arms scratch and sand very easy. Same on the new flanbloc, make sure it is smooth and has no creases and dents. Mine had a few dents and I made sure surface is smooth and shinny before I tried pressing it in.
    9. I used a little bit of grease on the inside of the arm and outside of the bushing before pressing it in. I started with just the vice and the flanbloc and pushed it in until I felt resistance, case when I had to use the big 1-7/16 socket on the side where bush was coming out, as it was already level with the arm. Hope it makes sense.. If not I will take more pics tomorrow. If I don't forget.
    10. Once you pressed the outer thing in, just slide in the center piece, put the 2 washers back (Watch for the order, the one with the slit on it goes last, just before the circlip) and then use the circlip pliers to put the circlip back.
    11. Honestly, in the last photo, it is all I used (plus a decent size vice) to do it. After I had my arm out of the car, obviously. The bush on the right is the new one, and the left is just the hole. Will be pressed tomorrow.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    areo, DeTomasoGTS74, Aku and 5 others like this.
  5. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,118
    Josh @jtcarprojects
    Step 2 is a must
  6. AandSC
    AandSC Formula Junior
    957
    Jax, FL
    Allen
    Thanks for the DIY write up! I feel like step 7 should be further up the list. Like maybe step 1.
  7. Mario Andretti
    1,777
    Boston
    I am working on the lower arm; totally different, much bigger. I am working on finding some sockets that match that one; will post later once done.
    LorenzoR and AandSC like this.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Did you have to fit new ones ? or just clean them up. If you had to renew them, how bad was the rubber bushing
  9. Mario Andretti
    1,777
    Boston
    Rubber bushing was all cracked at the edge, but they could have worked a bit more. They were not too tight, so arm was moving fine with no excess play. Problem is, the rubber got so hard in time, they were like poly bushings :) So I think I gained a bit of a more compliant ride with the newer softer rubber.
    There is not much to clean... the inside of the shafts were clean and had some kind of lube, so I think somebody in the past did that many moons ago.. So yeah, I pulled them all out and pushed new ones in.
  10. fstbiker
    fstbiker Formula Junior
    Jun 28, 2012
    510
    New Jersey
    Did you do the ballpoints at the same time? Seems like a good opportunity, since you had it all apart.
  11. Mario Andretti
    1,777
    Boston
    Balljoints? No, the rubbers seals are intact on both of them, and there is no play... They also look fairly shinny so I assume they have been changed before. I think they can go at least another 10k miles. Which is years in how much I clock ...
  12. Mario Andretti
    1,777
    Boston
    Ok, pushing out for the lower arms. The external diameter of the flanbloc is 34mm, so you need something 32-33 max to push it. I found a 24mm socket at autozone which was 31.8mm on the outside, and fit ok. Wish it was a bit bigger, but it worked.
    For the receiver, the outside of the flanbloc is 43mm, so anything 44 and above will work. I found a 1 11/16" socket also, which just about sits on the arm (a bit loose for my taste, but it does sit all around) . It looks loose in the pic, but it has hex channels/walls built inside which do grip on the arm (if you don't know what I mean, look at socket inside)
    Again, I warmed up the arm a bit, and slowly pushed it in with the vise.
    colorfull and AandSC like this.
  13. Mario Andretti
    1,777
    Boston
    To press in the flanbloc on lower arms, just use something flat against the bushing (it will be on the left of the picture above) and the receiver I showed you for the upper arms on the right side (this guy here is too big, so the other one fits perfectly as support).
    I forgot to take a pic, and my hands were freezing... bloody cold today in New England.
    Off to drink beer now.
    AandSC likes this.
  14. fstbiker
    Jun 28, 2012
    510
    New Jersey
    You should of just bought a cheap bushing press set off amazon, but sockets work also. Nice job!
  15. Mario Andretti
    1,777
    Boston
    #15 Mario Andretti, Dec 15, 2022
    You mean like this:
    Funny you said that :) ; my vise called the quits pushing out number 3 (one of the jaw supports cracked in half) , so I had to pull out my bushing press...Works fine with an impact gun on medium speed; it is moving slowly ...
    No kit will have the exact diameter sockets that you need for pushing/receiving (I have 2 kits) , so you still need to purchase the socket I have here most likely.
  16. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Wow that is a kit, as a poor man i will have to revert to my lathe again and turn down a bit of scrap iron
  17. AandSC
    957
    Jax, FL
    Allen
  18. Mario Andretti
    1,777
    Boston
    #19 Mario Andretti, Dec 15, 2022
    They are kind of useless.. you can only press them in with that (which is the easy part), but cannot press out due to the shape of the arm..
    There is a cheaper 20ton pressure one for 150 bucks, but it takes space, and its very easy to do in the vise or with a press... Each to it's own though. That will be very useful though if you start changing bearings and such. I am limited for space so I am saying pass.
    RANDY6005, Marcoboxer and AandSC like this.
  19. Mario Andretti
    1,777
    Boston
    I want to add that if you never changed your ball joints and you have no noises; go ahead and check them out. Remove the seals. If like mine, the balljoints are perfect, no play but the grease inside has dried out in time and becomes the brown goo stuff you see in this picture from aldousvoice.com (ok, mines are not that bad; I'll take some pics) .
    They are not bad, still serviceable. They can be washed/ cleaned to mirror like shine, and greased. Provided you do that, they will last a long time I think.
    I discovered a hole in one of the rubber seals, and took it out. That brown goo was pretty much dried grease.. I then removed the other side, which had no holes or tears, and sure enough, it was the same.
    I am opening now all of them and clean/ grease.
    Rubber seals are available at Ricambi by the way, for 25 bucks a pop (you can also re-use some, if you take them out carefully).
    AandSC likes this.
  20. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Use motor bike chain lub as it will get into every where, grease will just coat the surface u can see. Besides which it will tolerate water
    Mario Andretti likes this.
  21. Mario Andretti
    1,777
    Boston
    So one more update. When you get to the rear lower arms, you will have a bit of a surprise. The Flanblocs have studs stuck into them, with nuts and washers inside the car chassis. I was unable to remove them from the old flanblocs, no matter how much heat I applied.... I was scared to hit too much on the arm in the vise, so I decided to cut the old flanbloc (I will change it anyway) and remove it that way, and order new studs/screws. They are part number 182215 and usually not in stock, fyi...
    AandSC and colorfull like this.
  22. Mario Andretti
    1,777
    Boston
    Update2 : The studs can be removed once you cut the flanbloc, just need to push them carefully out with the vise and hammer them out. I used a M10x1.25 (NOT the original, bought a few from Home Depot ) nut on the thread so I don't damage it. They are VERY hard to punch into the new flanblocs but will go in with a bit of persuasion, and can be reused no problem. Cancelled my order at Eurospares.co.uk.
    Hope this helps. With around 1700 bucks give or take, depending on where you buy your parts; and with a bit of elbow grease, you can have a - like new - suspension. Other items I changed before are front shock absorber lower bushings and sway bar bushings (these make a very obnoxious knock if they are worn..)
    Cheers.
    colorfull likes this.
  23. Scottslaw
    Scottslaw Formula Junior
    Awesome man! Where did you order from to get it all for 1700? Eurospares? Also, have you been able to test drive yet? If so, could you tell a difference?
  24. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,621
    San Jose
    dc
    Thank you for the info. I have these parts sitting awaiting motivation. I personally felt the world of difference on trans/motor mount replacement but I do not track.
