Flanker low pass | FerrariChat
Flanker low pass
Discussion in 'Aviation Chat' started by jcurry, Nov 24, 2016.
  1. jcurry
    24,084
    In the past
    Jim
  2. NürScud
    NürScud F1 Veteran
    Nov 3, 2012
    7,308
  3. Ryan S.
    Ryan S. Two Time F1 World Champ
    28,879
    Fantastic!
  4. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,621
    Juan
  5. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    There was some discussion on another forum that there was an issue with #1 engine and that the whole thing was inadvertent. I'm not sure if there was any solid info behind that though you can see that #2 is producing the expected smoke trail but #1 is not.
  6. kylec
    kylec F1 Rookie
    3,670
    Orlando
    ^that would explain the yaw to the left.
  7. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Except he appears to be yawing right, unless you think he's stepping too hard into the good motor, which he's not as the rudders are both centered up if you check it in slo mo. I think both motors are just fine hence the rejoin on lead after the shennanigans.
  8. andrewecd
    andrewecd Formula Junior
    Dec 17, 2006
    543
    Andrew
    Looks like someone ate a jet blast at 0.56!!
  9. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    That was pretty amazing, but?
    Why couldn't they trim off the first 30 to 40 seconds? Would surely not detract from the clip, and would probably save thousands of hours of viewing time as people click on it...
  10. jcurry
    24,084
    In the past
    Jim
    You can get a sense of what may occur when you see the dust clouds being created by the exhaust deflecting off the ground. So you know they were very low even before the one split off. Plus it seems its always difficult to pick out the aircraft on a video. After multiple viewings it became easier to recognize the aircraft further out. YMMV.
  11. tazandjan
    39,169
    Definitely looked like the port engine was not running. Lucky the Flanker has a really good T/W ratio because it looked like he barely made it. Compressor stall on go-around has to be really fun.
