Flat battery Christmas lights | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by 430maybe, Dec 21, 2023.
  1. 430maybe
    430maybe Karting
    Oct 12, 2012
    112
    Northern England
    Full Name
    Hi. My battery went flat on my California 30 (2013) and now the ECU has a major problem - I know it's Christmas, but I don't want it lit up like a Christmas tree. Any advice would be most helpful?
  2. KS_California
    KS_California Karting
    Jan 24, 2022
    156
    Eastern KS - Just west of KC
    Werner Bartels
    Try charging completely with a quality charger - or if you care to remove the battery - take it to an auto parts store or shop that can load test it.
    spaghetti_jet and tomc like this.
  3. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    927
    Europa
    Bob
    As KS says above, fully charge the battery with a bench charger. Disconnect the battery from the car while charging.
    once fully charged, reconnect and follow the battery replacement procedure, that way you’ll avoid confusing the car with low voltage.
    if the battery is older than 3 or 4 years, consider changing it for a new one.
