Flat Battery in a Ferrari?....... you don't say. | FerrariChat
Discussion in '348/355' started by gidge348, Apr 8, 2009.
  1. gidge348
    gidge348 Formula Junior
    Dec 12, 2008
    343
    Perth West Australia
    Ian Wood
    Ok I admit, I was dumb.
    Had the motor out of my 348 for a few months fixing a burnt valve and a list of other minor bits and pieces.
    I thought I had switched the battery disconnect switch off but,..... obviously I hadn’t, & when I got everything back in and tried to turn it over…. Flat as a tack…… :(
    It should have kept a bit of charge; the battery is only about 4 months old so I must have a stray draw somewhere.
    Before I drag out the multi meter and test everything I noticed something unusual. When you turn the battery disconnect switch “ON” there is a click from a relay somewhere and the door lock buttons twitch. It does this both in the lock and unlock position.
    Just wondering if this is normal in other cars out there, if not it may narrow down what I have to look at.
    Have had a search of F-Chat for battery draws and can't see anything specific......... Any suggestions gratefully received…..
  2. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    The ECU's, clock, etc. all have a small current draw when the car is not running. That would be more than enough to drain the battery over a few months.
  3. SpecialK43
    SpecialK43 Karting
    Oct 12, 2007
    198
    Kzoo, MI
    K Russell
  4. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Yup.
    Unless you drive daily, the battery tender is your best friend.
    Kai
  5. Night life
    Night life F1 Veteran
    7,113
    The city that rhymes with fun in Canada
    Roberto
    +1
    I never use to believe this but after over a year of owning a Ferrari you tend to change your outlook on a lot of what is usually normal for other cars...:p
  6. f355spider
    f355spider F1 World Champ
    17,913
    Actually, any car made in the last 15 years or so that is driven rarely and on short trips, will suffer the same fate. I am on some BMW lists, and owners there show the same surprise if they suddenly drive their car only every other weekend for a short trip and find a flat battery after a couple months of this. Same solution...drive regularly or get a battery tender.
  7. PAP 348
    PAP 348 Nine Time F1 World Champ
    Dec 10, 2005
    99,176
    Mount Isa, Australia
    Pap
    Just thought I would add my 2c here. :D:D
    My car just the other day sat for 5 weeks before I went to the garage and started the engine. It started straight away, no issues. I didnt have time to drive the car, so I let it run for 5-10 mins and turned it off. :):)
    2 weeks later, I went to the garage to start the car and take her for a drive and I found the battery was flat. :rolleyes::rolleyes:
    I charged her up JUST enough to get her started and took her for a drive for 20 mins or so. Came home and parked the car for another 4 days. 4 days later, flat battery. :rolleyes::rolleyes:
    Then I went on holidays for nearly 4 weeks. Last week I put the battery charger on the car. The battery was THAT flat, it didnt look like the charger was doing anything and I thought the battery wasnt going to take a charge. I.E-dropped a cell. :eek::eek:
    But, after charging it for 48 hrs it was fine. Battery fully charged and car cranked over stronger than ever. :D:D
    I took her for a drive and enjoyed EVERY minute of it. ;);)
    So I wouldnt stress about a current draw there mate. Sitting for a few month is bound to flatten the battery in these cars. :):)
  8. gidge348
    Dec 12, 2008
    343
    Ian Wood
    #8 gidge348, Apr 9, 2009
    Thanks all....
    Looks like my car is behaving ........ "Normally".....
    I bought a new Ducati St3 a few months ago and noticed it came with a "Battery Fighter" charger in the bag of stuff, thought it was a bit of bad omen for Ducati electrics, but looks like I will get one for the 348 as well.
    Just waiting for the injectors and all systems go, apparently they are still not flowing to 100% got a heap of disintegrated fuel pump mount rubber through the system and is proving to be a bit stubborn to shift.
  9. notbostrom
    notbostrom Formula Junior
    May 8, 2006
    957
    Orlando, FL
    Ben
    It's a weekly ritual for me in the winter. Every Friday I switch the Bat tender from the 348 to the Monster and then back the following week.
  10. msa
    msa Rookie
    Jul 19, 2007
    44
    Linkoping
    Marcus Ahlberg
    Check out my post in the technical Q/A section about the battery kill switch.
    it can help to clean all the connections to the battery,
    but of course if you leave the car for weeks you should use some kind of charger.
  11. vvassallo
    vvassallo F1 Veteran
    8,281
    Palos Verdes
    Vince V
    My lasts about 2-3 weeks or so before the battery is almost too weak to start the car. I either drive it weekly or charge up the battery every 10 days. Yeah a tender would be nice but I don't like to have stuff plugged in the garage without me watching it. When 'i had my Spider with alarm and stereo it lasted a week only before the battery toasted. At least this car is much less demanding.
  12. SonomaRik
    SonomaRik F1 Veteran
    6,880
    Sonoma, CA
    #12 SonomaRik, Apr 9, 2009
    another two cents. Very common if not on tender to have a low or no voltage.
    However, currently[sic] on the 456, this weekend will be spent diagnosing a brand, new battery put in couple weeks ago [old one had a dead cell], where the battery goes flat in just 24-30 hours. Completly dead to the point the clock or key fob won't work.
    will spend time pulling fuses, seeing the draw, then replacing....the only fun part of this event, Sat., is baby gets a brand new set of shoes. :D
    PS: I know the alternator and such is ok, what I'm thinking and I'm no eletrical genius, but, in the olden days, like tubes and all, I remember the adjustments some circuits made when a tube started going bad. The remaining tubes would adjust to the changes. It wasn't uncommon to replace/fix an errant tube only to find the others start to go bad either immediately or quite quickly as their adjustments to the replacements were too sudden.
    SO: I'm wondering, in these 'ECU' type of circuits if something similar isn't happening. I know, they are solid state, but there are a bunch of sensors/relays that are somewhat mechanically electrical to make such circuits start to fail like in the 'olden tube days'. Perhpas someone with more electrical insight can put that to rest.
    rik
  13. PAP 348
    Dec 10, 2005
    99,176
    Pap
    Bloody hell!! I wonder how long they had crap in them?? :):)
    You and the previous owner were VERY lucky that you didnt blow a hole through a piston!! :D:D
  14. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,352
    Indian Wells, California
    Jon
    I use one of the Griot's Garage battery managers on the 328. It just sits in standby mode unless the battery charge drops below full. The 328 has nothing except the clock to drain the battery, though, so the battery manager doesn't kick in that often.
    I like the fact that the alternator doesn't have to work as hard after the engine is running.
  15. Billdemart
    Billdemart Karting
    Mar 30, 2009
    92
    Atlanta, GA
    Billy D
    Not to derail but what is a "Flat" Battery... Is that the same as a dead battery? I've never in my life heard that term.
  16. aaronm
    aaronm Karting
    Mar 10, 2008
    59
    Australia
    my car has a kill switch located in the engine bay close to the battery. When i turn it on i can here the central locking. Is this switch a standard feature or something the previous owner put on?
  17. gidge348
    Dec 12, 2008
    343
    Ian Wood
    Flat means dead, no power, kaput, nada, niet broom broom......
    Sorry did not realise the term was not in general use,.... must be an Ozi-isum :)
  18. gidge348
    Dec 12, 2008
    343
    Ian Wood
    I guess I was, only to have a couple of valves die.
    Like I said before if anyone has the fuel pump rubbers go to S**t, time to change filters, clean the tank, clean the fuel rails, regulators, return lines AND at least have the injectors checked...... unless you have burning desire to see what the inside of a Ferrari engine looks like.
  19. f355spider
    17,913
    Since you never filled out your profile, how are we to know what car you have? ;)
    But since you are in the 348/355 section, I have never seen one with a shut off switch in the engine compartment, except when added by the owner.
  20. Night life
    7,113
    Roberto
    I thought the older 348 had the kill switch in the engine bay...
  21. aaronm
    aaronm Karting
    Mar 10, 2008
    59
    Australia
    mines a '91 348 TB, the switch is close to the battery
  22. PAP 348
    Dec 10, 2005
    99,176
    Pap
    Yep yep!! Thats RIGHT! :D:D
    One was burnt out was it?? :):)
  23. gidge348
    Dec 12, 2008
    343
    Ian Wood
    Yep one was burnt, but the other exhaust on the same cylinder looked suspect so that went over the left shoulder as well.
    All others had a good seats and sealing, all had minute amount of guide wear but not more than expected in 20,000ks so left well enough alone.
    Compressions now all either side of 190lbs per cylinder, the cam timing is "right" now but as the previous "expert" said "A tooth or two either way is "not a problem" ....50lbs difference in compression "not a problem". Yeh Right
    Brakes, clutch and coolant bled spun up oil presure today hangin out to get the injectors back and go for a run.... :):):):):):):):):):):)
  24. Zanny1
    Zanny1 Formula Junior
    974
    Arizona
    So would you recommend using a tender with the battery disconnected in order to leave the F-car in storage for 5-6 months at a time? Or would you use the tender with the disconnect switch in the connect mode so all electronics in the car are in a function mode? I have several vehicles (MBenz ML 320, GMC Sierra, HD FLHT) left 5-6 months at a time with tenders and never have any problems. This is required because I work overseas.
  25. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    I have had a different experience with my 348. It has never been hooked up to a battery tender, and it has sat for some long periods between drives. The longest has probably been around 3 months. It starts up everytime without issue. I am glad that I don't have an aftermarket alarm system, they are well known for causing dead batteries.
    BT
