Flat lined 02 sensor | Page 2 | FerrariChat
Discussion in '348/355' started by drbob101, Nov 15, 2014.
  1. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,831
    Lake Villa IL
    The rear o2's should not be switching/following the front o2's. If so the cats are not functioning or they are missing.
    I like to see this stuff in graph form. Your first picture looks like a very slow sample rate.
    So, still need to see a nice graph of all 4 o2's. Fuel trims, and what symptom is leading you to believe there is a problem.
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    He is getting bank 2 O2 sensor codes.
  3. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,831
    Lake Villa IL
    Yes, what codes specifically.
  4. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #29 drbob101, Nov 17, 2014
    I am going to create a panel that has all 4 sensors and st/lt fuel trims as well.
    I got a sensor inactivity code and others. I cleared them but I will post them when I run it again
  5. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    The refresh rate with that many PIDS is going to be slow. Not saying not to do it, just letting folks who actually understand how to read this stuff (not me) know that so they aren't mislead by the results.
  6. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Watch that vid I posted above He does a great job explaing the 02 sensor fuel trim relationship and what it should be and how it should react , etc.
  7. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Here is a vid of the panel I made with all the 02 sensors and fuel trim pids
    The right side is h/l/current value. The left side is just the current value.
    This was from a cold start. About 40 degrees in the garage I would say. It went into closed loop around the 2:40 mark on the video.
    Note the rear bank 2 sensor is flat lined at that bias voltage.
    [ame]http://www.youtube.com/watch?v=vKITN8r0W2c[/ame]
    Bob Ferraris
  8. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Ok, so we are still at either a bad connection or bad sensor. Something is causing an open circuit. I'm not sure I would do this, but if you unplugged the sensor and shorted the ECU signal and ground wires together I would expect to see the 0.435V drop to 0V or close to it. If it did then that would tell you the ECU side of the wires are good and the sensor is definitely the problem. If it doesn't drop to zero then there is a bad connection or bad wire (open circuit) on the ECU side.
    Or you could connect a old, weak 1.5 V battery between the ECU signal and ground wires and you should see the voltage rise to the battery voltage if the connections/wires are good. (Positive side to signal wire).
    Or you could do the "battery touch test" as in the video but that would only tell you is the signal wire is good.
    I can see you are enjoying yourself here, Bob.
  9. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Its great to be able to see the actual values real time rather than staring at an idiot light or a static code reader. It helps understand what is actually going on.
    I'm going to just unplug the old sensor and see what happens to that bias voltage then plug in the new one. I'll do the other line tests as you said also just to check them and understand that bias voltage better.
    Yes John...its getting cold and dark and you go into make work mode. :)
    The OBD device and app cost all of $30 total BTW. Pretty cool.,
  10. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    I have Scan XL Standard. Cost a little more and probably didn't need it but it does a little more, not that I've ever used it. I can not see how anyone can make decisions on what to do w/o this kind of software. I wonder how many $1600 a pop plus labor "fixes" have been done to correct problems that would have easily been detected can simply corrected with $30 - $100 worth of software.
    By the way, compared to our friend Dave up north, it's plain balmy around here at 35*F. May I'll go out in the Boxster with the top down today. :)
    This is the problem with being retired in CT. It's hard to get motivated to do anything except waste time on the net when it's like this.
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    John, check out the Bear Mountain Rally in NY section. I may go this weekend. Not a bad drive for you.
  12. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Going to the Hartford International car show this weekend. Jeanne want a new car. She's thinking about a Mercedes GLA.
  13. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Oh man thats my old stomping grounds. Tweed blvd just south of there was my favorite place to go fast, dropped my R5 turbo and 930 off the side several times LOL Lots of houses up there now, even the missile silo is gone now
  14. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    No foliage up there now so a little late for this but if its clear I may venture. Theyre doing brunch with unlimited Mimosas afterward in Rivervale. Maybe we'll swing by FNA after wave :)
  15. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Back in 1969 I was returning ti CT from visiting a college buddy still at Penn State. I 84 was not completed yet. I took 209 out of Stroudsburg PA north to US Rt 6 and then across Bear Mountain in my 1969 Z28 which just happen to have the diaphragm in the power break booster fail on the way home. I remember coming down the east side of the mountain with no power boost, standing on the brakes as hard as I could. This was a car with the JL8 4 wheel disk brake option and w/o power assist it was like dragging you feet to stop it. Haven't been back out that way for a while. I'll have to put it on my calendar for next summer.
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    #41 SoCal1, Nov 18, 2014
    You know I just remembered something, you said you have a 308, I remember in the early 80's many 81. I went up the NY Thruway got on just north of the Tappan zee at the first toll booth ran with a 308, and BMW I was in a red 930 to the Albany exit in 1 hour 03 min early one Saturday morning, I remember because a trooper was at the exit and was handed my toll ticket. I think 127 miles or so in an Hour 3 minutes. Good thing he was a car enthusiast and took my PBA card. I think they were waiting for me LOL
    EDIT My memory may be off, may have been driving a white RX7 full GTU car, no decals with dealer plates
  17. mfennell70
    mfennell70 Formula Junior
    Nov 3, 2003
    621
    Middletown, NJ
    The cat stores and releases oxygen. The rear O2 voltages DO oscillate, just at a different (slower) rate from the fronts.
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,831
    Lake Villa IL
    Yes I should have worded that differently. You are correct they will oscillate but they should not mirror the primary 02's.
  19. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Well that was to easy. New sensor just plugged in.
    Now what am I going to fix this winter? Ob I know I'll fix my Spider top. Oh wait that isn't broken!!! 😜
    [ame]http://www.youtube.com/watch?v=UjVRVh1nsVA[/ame]
    Bob Ferraris
  20. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Bob, It only took you 19 days!
  21. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #46 drbob101, Nov 19, 2014
    Well it's cold out and you have to string these things out.
    "Work expands to fill the time allotted to it"
    I did get some useful things out of this.
    A better OBD system
    An understanding of how to see fuel trim kick in
    How to back test the signal line using your body.
    O2 sensors can go after a bit over a year??? I wonder if something in my car made this happen?
    My left OEM cat fragmented, this is the left rear 02 sensor. Coincidence?
    Now I have to get my hands dirty.
  22. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    I want to point out another thing here. I have read a lot about failed headers resulting in excess oxygen being entrained into the exhaust with the result that the car goes full rich with resulting engine damage. The thing is that if these is excesses oxygen in the exhaust driving the car rich you should be able to see that in either or both the O2 sensor and the term fuel trim. Excess oxygen, resulting in a lean condition, would drive the upstream sensor to a low voltage and the fuel trim to a high positive percentage, long term, short, or both. So while there may be numerous reasons for excessively rich fuel trim, bad MAF, vacuum leaks, burnt valves, bad O2 sensors, as well as exhaust leaks, I would expect that if the long and short term fuel trims are within normal ranges the headers are not in bad shape, or at least excess O2 is not being entrained into the exhaust through them. (Use this info at your own discretion.)
  23. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,831
    Lake Villa IL
    Agreed with all of the above post^^
  24. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Watch this short vid, on particular point 6. In a misfire resulting in unburnt fuel, the o2 sensor will read that as a lean condition and adjust the fuel trim to richen the mixture.
    It seems to me that this is where you might get into a destructive loop of unburnt fuel in the cats
    Comments?
    Check out this video on YouTube:
    http://youtu.be/x5cSO1xGj0o
    Bob Ferraris
  25. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
