Flew a 182 RG two days this week | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by Chupacabra, Jul 29, 2015.
  1. tazandjan
    39,374
    No such thing as too much horsepower. Too much weight, yes, hp, no.
    Boomhauer likes this.
  2. jcurry
    24,153
    In the past
    Jim
    What engine?
  3. jcurry
    24,153
    In the past
    Jim
    What engine do you have?
  4. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    O-470-50
  5. jcurry
    24,153
    In the past
    Jim
    Figured. I put one in my 180 and flew it wheels and amphibs. Had an 86in McCauley wide-chord 3-blade. Pulled really well. However, I would not do it again. The biggest plus of the carb engine is starting. The bad, to me, was the horrible induction system of the O-470. Had horrible fuel distribution. The 6cyl engine analyzer showed EGT spreads of well nearly 200deg at TO, with the accompanying CHT's. I ended up running a very small amount of carb heat ALL THE TIME, yielding better atomization and creating a little turbulence in the induction, all of which resulted in much more even fuel distribution. Was able to get CHT spread less than 50 on TO. So I probably ended up with slightly less max HP, but likely saved a couple of cylinders from burning out. FI is the way to go, which also allows running LOP. YMMV. The 50's 180/182 were light, so the added HP with the new props is a lot of fun.
  6. Hannibal308
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Nice run down...thank you!
