Flickering Dash Lights | FerrariChat
Discussion in '456/550/575' started by scowman, Mar 17, 2018.
  1. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    1995 456 GT Six Speed.
    So I was driving to the inspection place this morning with the running lights on and the dash lights started flickering. I could get it to do this when I touched the brake pedal engaging the brake lights.
    Thoughts on where to start with this one?
  2. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    It does not do this at a stop, just when moving so I'm thinking a lose + or - wire somewhere. It's also all the dash lights including main cluster and the center dash gauges. They all flicker in unison. Is there a decent wiring diagram for the GT? Anyone been under the dash. I assume there is a single power source, but is there a single ground or do the lights ground as the sockets?
    Maybe the switch on the column?
  3. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    710
    Toronto
    Ryan
    I had an issue with dash lights on my 550 flickering while driving every once in a while. Turned out to be a bad connection in a connector to the fuse box. Found it by wiggling wires until I hit the right one and the dash lights flickered. Fixed the connection, never happened again.
  4. Lionworks Auto
    Lionworks Auto Formula 3
    Oct 16, 2013
    1,023
    Worthington OH
    Ed
    You might also check the dimmer switch married to the hood release panel - that often goes bad and can cause the dash lights to flicker (did mine). An easy replace thru Ricambi.
  5. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Thanks for both ideas. LWA how do I check the dimmer?
  6. Lionworks Auto
    Oct 16, 2013
    1,023
    Worthington OH
    Ed
    #6 Lionworks Auto, Mar 24, 2018
    It’s coupled with the hood release - there is a wheel switch to the right - see if when you play with it if the lights flicker. Can also remove it and check the connectors, ensure no corrosion. My switch simply went bad and ordered a new from Ricambi and fixed the issue.
  7. Lionworks Auto
    Oct 16, 2013
    1,023
    Worthington OH
    Ed
    Seems the photos may not have uploaded correctly. Trying again... Image Unavailable, Please Login
