Flight checks. | FerrariChat
Flight checks.
Discussion in 'Other Off Topic Forum' started by Fan512bbi, Sep 7, 2006.
  1. Fan512bbi
    Fan512bbi Two Time F1 World Champ
    20,938
    Wales-UK
    Steve.
    It takes a college degree to fly a plane but only a high school
    diploma to fix one: a reassurance for those of us who fly.
    After every flight, Qantas pilots fill out a form, called a "gripe
    sheet," which tells mechanics about problems with the aircraft.
    The mechanics correct the problems, document their repairs on the
    form, and then pilots review the gripe sheets before the next
    flight.
    Never let it be said that ground crews lack a sense of humor.
    Here are some actual maintenance complaints submitted by Qantas'
    pilots (marked with a P), and the solutions recorded (marked with
    an S) by maintenance engineers.
    By the way, Australia's Qantas Airlines is the only major airline
    that has never had an accident.
    P: Left inside tire almost needs replacement.
    S: Almost replaced left inside main tire.
    P: Test flight OK, except auto-land very rough.
    S: Auto-land not installed on this aircraft.
    P: Something loose in cockpit.
    S: Something tightened in cockpit.
    P: Dead bugs on windshield.
    S: Live bugs on back-order.
    P: Autopilot in altitude-hold mode produces a 200 feet per minute
    descent.
    S: Cannot reproduce problem on ground.
    P: Evidence of leak on right main landing gear.
    S: Evidence removed.
    P: DME volume unbelievably loud.
    S: DME volume set to more believable level.
    P: Friction locks cause throttle levers to stick.
    S: That's what they're for.
    P: IFF inoperative.
    S: IFF always inoperative in OFF mode.
    P: Suspected crack in windshield.
    S: Suspect you're right.
    P: Number 3 engine missing.
    S: Engine found on right wing after brief search.
    P: Aircraft handles funny. (I love this one!)
    S: Aircraft warned to straighten up, fly right, and be serious.
    P: Target radar hums.
    S: Reprogrammed target radar with lyrics.
    P: Mouse in cockpit.
    S: Cat installed.
    And the best one for last...
    P: Noise coming from under instrument panel sounds like a midget
    pounding on something with a hammer.
    S: Took hammer away from midget.
    __________________
  2. Der Meister
    Der Meister Formula Junior
    Aug 16, 2005
    657
    Glendora/Prescott
    Alan
    theres a reason we fly and they fix.... :)
