Flow Testing Results of OEM CIS Injectors | Page 3 | FerrariChat
Discussion in '308/328' started by dave80gtsi, Dec 6, 2010.
  1. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,337
    Encino, Ca
    Carl T
    I understand that after replacing the injectors it is required to adjust the mixture at the fuel distributor with the use of a exhuast gas anylazer. I thought that the K Jet ECU has fixed values and therefore can't signal to the fuel distributor to make changes to the fuel mixture. If the mixture is set at the factory and the anti tamper plug has not been touched, then why would one need to tweek the mixture after injector replacement? Would this be due to the +/- 20% error variation found when testing?
  2. Rifledriver
    37,072
    #52 Rifledriver, Dec 8, 2010
    K Jet has no ECU. The ECU in the system only controls the frequency valve based on the signal from the O2 sensor. That component only modifies the base setting in steady state situations. The base setting is established via the main mixture screw and has primary authority over mixture.
  3. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,337
    Encino, Ca
    Carl T
    Ok, just mispoke about the ECU, actually a signal processor. So if the base setting has never been manually adjusted then why would one need to fuss with it after installing new injectors? I have read many threads that comment on how after replacement of injectors one ends up with a rough idle(usually lean) and perhaps reduced performance until a new base setting is established. Maybe I'm wrong about that and in fact the new injectors are actually "failing"? Just trying to get to the logic behind this.
  4. Rifledriver
    37,072
    I have been working on them professionally since they still had carbs and I have never heard that. Maybe those guys had more experience, I don't know.
    Changing injectors can have an effect on mixture and it should be checked. Besides making the car run properly is what the desired goal is. Why even consider one of the most important adjustments in that process? I cannot even concieve of leaving the job half done.
    If I put a new tire on your car would you consider it advisable to check the pressure?
  5. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,337
    Encino, Ca
    Carl T
    #55 cmt6891, Dec 8, 2010
    Thanks. Good analogy.
  6. dave80gtsi
    dave80gtsi Formula 3
    1,916
    Ohio
    Dave Meredith
    #56 dave80gtsi, Dec 20, 2010
    Many thanks for all of the kind comments and feedback offered to date on this very interesting topic.
    Just to bring this issue to a close, I purchased four (4) more new identical CIS injectors, which now gave me a pool of twelve (12) such new injectors to work with. I then asked my testing guy to flow check the entire lot, and to select the “best” eight (8) out of the pool, i.e., those whose flow rates most closely matched one another.
    See enclosed flow test final results.
    The final set of eight (8) injectors which were selected all have crack-open pressures falling within a low / high range from 4.0 to 4.1 bar (not shown on this flow summary page). This is likely to be as close, one to the other, as I could reasonably hope for.
    The Bosch / Ferrari factory spec for this crack-open parameter is given as 3.0 to 4.1 bar, so I note that I am now within this spec, albeit right at the high side of their acceptance range. And to refresh your memory, you might recall that this parameter range for my old OEM injectors was 3.6 to 4.7 bar, so I’ve made real progress there.
    I very much appreciate the comments put forth here earlier which state that this injector flow rate is not a critical parameter.
    However, my thought process here is that it is not likely that I will ever replace these injectors again during my anticipated life with this car (recall that these new injectors replaced my old OEM 30 year old ones, so I seem to be on a pretty long maintenance cycle for these).
    Since these CIS injectors are an inexpensive commodity item, I simply wanted to do it “right” the first time by eliminating any potential for the possibility of flow mis-match between the new injectors, strictly in the name of elimination of this as a variable and to thus aid any future trouble-shooting. (Once again, with the respectful qualifier that I fully appreciate the comments posted earlier stating that this is really a non-issue.)
    For me, it’s just like eating some chicken soup when you have a cold. It sure can’t hurt. And if I had just blindly installed a set of untested new injectors, I would not have had any confirmation whatsoever that my new ones would have been any better than the old ones.
    Now I can confidently rule out these injectors as a potential source of any future fuel delivery problems, should any such fuel related problems ever occur. Plus, as a bonus, I also have a set of four new (4) emergency injector spares ready on the shelf, if I might ever find a need for these.
    All in all, I figure that the work that I have done is just cheap insurance.
    Since I now have a verified set of injectors (at least, in the relative sense of the use of that phrase), my work on this project is done, and it is time for me to move onwards to other projects.
    Thanks - DM
  7. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    As usual Steve explains it simply and correctly.
    Brian, I agree that 95% of the time glowing headers are ignition related. However I must relate a personal experience. My Mondial had glowing headers, but only in light driving/idling. Around town and such. Not glowing cherry red and visible in daylight, but if you opened the engine lid at night, they were definitely glowing. I checked the mixture and instead of being around 13-14:1, the car was running 40:1 at idle and down to about 20:1 at light throttle. Not sure how the car even ran that lean, but it did! Verell and I tweaked the K-jet with a gas sniffer and no more glowing headers. Extreme lean running will produce glowing headers, believe me!! So my advice to climb is to put a gas analyzer on it. It probably needs new injectors and a k-jet tweak. Very simple operations both. Here's my fuel injector tutorial with thanks to Bertocchi.
    http://www.birdmanferrari.com/service/injectors/injector_clean.htm
    By the way, the injector cleaning and mixture tweak made the car run a zillion times better. It starts SO easy now.
    Birdman
  8. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    #58 climb, Dec 20, 2010
    What is the ratio for a 1980 injected USA spec 308?
    I've taken a can of fuel injector cleaner and put the straw right into the injector tip and let each injector have it. I Used 3 bottles of the stuff between the 8 cylinders. No i couldn't see the pattern but i feel they were cleaned. The cans would stop spraying after 2/3 of the can was emptied since the propellant at that level couldn't keep the injectors open. All the injectors had this resistance to the lessened force of the can.
  9. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I'm not an expert on mixtures, but 14.7:1 air:fuel is the "ideal" stoichiometric ratio. Right around that number is where you want to be in general. If the headers are glowing due to being lean, it will be way way off. Not a little off. If the mixture is in the ballpark, the glowing is timing like Brian said.
  10. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
  11. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    #61 climb, Dec 21, 2010
    I know this sounds kinda clueless but i'm sick of driving an igniter around..
    Is the ratio adjusted by turning the mixture dial on the throttle body in-between the black air hose and the plenum? That is if i took it to a garage that had a gas analyzer could the knob be turned 'till the ratio was was 14.7:1?
    Oh, and 36mm on the crank pulley to turn with a breaker bar in clockwise direction?
  12. Rifledriver
    37,072
    You said it yourself "Headers". He has glowing "Header" as in one.
    Fuel system problems will effect both equally. Cam timing and ignition strike individual banks.
    Auto diagnosis 101.
    If you hear hoof beats do not look for Zebras.
  13. Rifledriver
    37,072
    Waste of time.
    Address the symptoms.
  14. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    I'll check cam timing next then do the gas analyzer if timing is good.
  15. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    There are threads on how to adjust the CIS mixture but you wouldn't go there till you knew the cam timing was right.
    Once you know the cam timing is right then you need a gas analyser you know you can trust.
    Before you do a mixture adjustment make sure any and all vacuum and CIS air hoses are secure and not leaking.
    Adjustment needs a 3mm Allen key & the adjuster is on the CIS head under a cover screw. Clockwise makes it richer, anti-clock to lean it off.
    Make sure you have the thing idling at near enough 1000 - don't trust the tacho (mine is at least 100 off at that speed) , use a meter. As you make an adjustment the idle may change & so you may need to reduce/increase it between adjustments back to 1000 to get an accurate reading (use the air idle screw).
    In between each adjustment you need to block off the cover screw hole or replace the cover screw to get an accurate reading because air leaks in there & will distort the reading.
    Adjust in tiny increments, its very sensitive & always make the last adjustment going clockwise (richer).
    When you are done you should be able to drop the idle down to 850-900 ish using the air adjuster screw under the throttle body.
    ...but as Brian basically said - check your cam timing first.
  16. Badman
    Badman Formula 3
    Mar 4, 2007
    1,116
    Gotham City
    Bruce Wayne
    Keep in mind that while 14.7:1 is the theoretical ideal for combustion, it isn't necessarily where you want your car to be. A little richer than ideal may provide better power, a little leaner fewer emissions. It's actually a pretty complicated matrix for best mixture, which is one reason why modern cars have complicated fuel maps.
  17. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I missed that detail! ;)
  18. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    But if you only have ONE glowing header, it's not the mixture! The mixture affects both banks equally! Like Brian said. Sorry for the confusion.
  19. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    #69 Birdman, Dec 22, 2010
    Hey Climb, my advice, which is worth less than what you pay for it is:
    1. Be absolutely positive sure that you have only one glowing header. If the front one is glowing too, I would suspect your mixture.
    2. If it's just the rear header, you probably have a cam out of time, because there isn't really anything to be "adjusted" in the GTSi ignition system. The crank sensors are fixed, the ECUs have no timing adjustment and neither do the distributors. It either sparks at the right time or it sparks not at all.
    When mine was doing it, I first thought it was only the rear bank because that's the one you can see. The front is pretty well hidden.
    Birdman
  20. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    I see.
    Gotta try to get a view of the front bank somehow.
