355 - Fluid capacities and preferences after engine out | FerrariChat
355 Fluid capacities and preferences after engine out
Discussion in '348/355' started by krazykarguy, Mar 19, 2019.
  1. krazykarguy
    krazykarguy Formula Junior
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    Hi all -
    I searched briefly, sorry if this has been asked in the past. I'm hoping for a few quick and concise answers...
    The engine is going back in today following our major service and I need to know the following fluid capacities:
    * Engine oil: External oil tank and oil cooler removed and drained during service, engine 'sump' drained from below. How much oil to put back in? Owner's manual states 2.5 gallons (9.5L) - not sure if this is full capacity or what gets replaced at an annual service. Is it proper to put in a couple of gallons and then monitor the oil tank level with a running motor? It seems like Mobil1 0W-40 is the preferred lubricant? If not, what?
    * Coolant: how much to refill and what is the preferred brand? OM states 2.9 gallons (11L)
    Thanks in advance!
  2. tatry68
    tatry68 Karting
    Oct 27, 2013
    120
    Chicago Suburbs
    Stan
    When I did my engine out, I put in about 9 quarts and then I checked it running with oil temp at about 150 degrees, the oil level should be between the low and full mark on the dipstick. Everyone has their own favorite brand of oil. Mobil 1 is fine. Ferrari recommends pennzoil 5w-40. As far as the antifreeze goes, I used the blue bmw coolant and I don't remember how much it took. I used the vacuum fill method and it worked great. No air pockets and no need to bleed.
    RCKSTR and krazykarguy like this.
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I many peo0le use mobil one, probably most common. I put in about 1 litre less than the manual states sthen start the car and start checking it once the engine fans kick in. I use 5w30 but that can vary a bit. If you do a search there is alot of discussion and a lot of good arguements.
    For coolant I use bmw blue coolant and again one of the more popular.
    For transmission its redlline again likely most popular. Also good discussions on here about the different additives and which. O8l not to use. I think mist agreed redl8ne shockproof was the not to use but do not quote me on that do the search.
    Again manual states for coolant. I th8nk it was around 8 litres but check. Your service manual.
    Oh and if you did the service yourself congrats
    krazykarguy likes this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    Start with …
    8 quarts of oil, then add
    3 gallons of coolant is plenty
    1 gallon of gear box oil + a little bit
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
  6. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,015
    NE FL
    Ken
    Start with 9qts of pennzoil euro platinum 5w-40, Check it, then add accordingly. I think i used all 10. I get it from amazon
    I used the zerex g-05 antifreeze as well available at autozone etc.
  7. krazykarguy
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    Thanks for all the advice!
  8. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,013
    PA
    Kevin
    The workshop manual is your friend. FYI total coolant capacity is 2.90 US gal.
  9. Rifledriver
    37,082
    Dave rocks likes this.
  10. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    756
    Vermont
    john truskowski
    So what would be the change interval on this product? 5 years?
  11. Rifledriver
    37,082
    Yes.
    Coolant additive packages are age sensitive, not mileage. Most are good for 300,000 miles provided you do that within the time limits.
  12. krazykarguy
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    Is there any recommendation for priming the oil system? Disconnect the coils and crank for 10 seconds?
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    If you feel the need Matt and have a car with an immobilizer that does not cut the starter off, just don't disarm the immobilizer and give it a crank.
  14. Rifledriver
    37,082
    Chances are it is going to crank a while to purge the air from the fuel system.
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Good point.
    Keep in mind, you did not rebuild the motor (if you did, assemble lube would be good) so the parts will still have an oil film.
    Rifledriver likes this.
  16. Rifledriver
    37,082
    Yup. Oil pressure does not lubricate engines, oil does.
  17. Skippr1999
    Skippr1999 F1 Rookie
    4,506
    Where are you guys getting
    Shell Rotella Ultra 50/50 ?
    All I’m seeing is big drums of it online.
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,892
    Central NJ
    Dominick
  19. Skippr1999
    4,506
  20. Rifledriver
    37,082
    Because it is used by so many fleet operators. I want it in 55 gallon drums in concentrate but cant get that. I hate paying $20 a gallon for water.
    I can buy antifreeze cheaper in 1 gallon bottles than I can in a barrel.
    Might call the local Cat dealer and get CAT ELC.
  21. Skippr1999
    4,506
    I get it.
    Hope you’re doing well.
  22. Rifledriver
    37,082
    Just fine thanks.
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    We get our cat elc in 250 gallon totes
