Fluid Dripping From Rear of SF90 | FerrariChat
Discussion in 'Technical Q&A' started by ebschor, Oct 13, 2023.
  1. ebschor
    ebschor Karting
    Jan 30, 2015
    53
    I have driven the car approximately 80 miles. After driving it home, I put it on my lift. Today, about five days later, I lowered the car and noticed pink, slightly viscous fluid dripping near the right, rear passenger tire from some sort of overflow hose. From what I can discern, it looks like F1 transmission fluid.
    Does this look like anything to be concerned about? Maybe this post will help someone else!
  2. colorfull
    colorfull Formula 3
    2,332
    Franklin Park, New Jersey
    John Napoli
  3. Llenroc
    Llenroc F1 Veteran
    5,488
    Colorado
    Vern
    Its a coolant leak, probably a hose not tight enough
  4. RayJohns
    RayJohns F1 Veteran
    7,920
    West Coast
    Ray
    Usually when liquid dries like that with that white chalky appearance, that's gonna be coolant. Hydraulic fluid / oil doesn't evaporate that quickly or leave that type of residue. Could just be that your coolant overflow tank is dripping out a bit of excess overflow, although I am certainly no authority on the SF90.
    As Vern mentioned above, it could just be a hose clamp issue as well, although that's a fairly large amount of coolant for just a hose clamp not sealing 100%
    Ray
  5. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    918
    Georgia
    Mark Gronsbell
    Looks like coolant. The SF90 has a DCG transmission not an F1 system. The cooling system in that car is quite complex with more than 1 coolant reservoir etc. Take it to the dealer.
    ebschor likes this.
  6. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,814
    Bologna
    Slightly overfilled coolant reservoir?
    Ferrari Tech and ebschor like this.
  7. Xrayv8
    Xrayv8 Formula Junior
    998
    New Jersey
    Xray
    I had the same thing happen on my 458 after it came back service recently. First thing service said was it just below a black hose? Turns out in my case it the overflow pipe from the steering fluid which can seep out after a drive especially since the steering fluid was drained and refilled on this last service. Only happened once and now the floors are dry and no issues with the engine.
  8. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,216
    Georgia
    Wade Williams
    It appears to be coolant. This is not uncommon as these cars need a bit of air gap in the reservoir system. If it is slightly over filled, it will purge the coolant when it sits and heat soaks a bit in the garage after a drive. I have seen it many many times. I would recommend a drive and park. I suspect you will see nothing further except good time and smiles driving that thing.
    f355spider and ebschor like this.
