Fluid leak 355 spider | FerrariChat
Discussion in '348/355' started by Dutchman, Feb 12, 2011.
  1. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    I noticed a large puddle of blue fluid under the front of my F355 spider after I returned her in the garage. I tested the container for the screenwasher by pouring in some new fluid, and it ran straight to the floor. :)
    Probably the container broke or a tube snapped loose. Can someone tell me what the easiest way is to reach this container?
    Thanks.
    Ton
  2. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    Nobody ever renewed this container? :)
  3. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Hi Ton,
    Never done it but after looking at mine I would remove the front cover in the left side front wheel arch (six set screws, the same set up as for the battery cover on the right front side). Looks to me that the container "lives" in there. Maybe the container is split or (hopefully) there is a leak at the connections - most likely on the way out at the bottom of the container.
    Good luck!
    Ron
  4. ronrob
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    I should have added that it's not absolutely necessary to remove the wheel to get access to the container in the first instance. It's such a pain to jack up the car. Put the car on full lock (as if you are turning extreme left). This will give you enough room to unscrew the six set screws to see if you can identify the source of the problem. However, you MAY have to remove the wheel to effect the repair. In other words, I don't know if there is room to remove the container and work in there without removing the wheel.
  5. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    Thanks Ron,
    I am will give t a try right now. :)
