430 - Fluid leaking on floor - F1 fluid? | FerrariChat
430 Fluid leaking on floor - F1 fluid?
Discussion in '360/430' started by oc23, Jun 10, 2024.
  1. oc23
    oc23 Formula Junior
    459
    Rob Yo
    Hoping I can get a quick diagnosis here. Never had anything leak on the garage so far in two months of ownership, but I drove the car for a quick drive last Wednesday. Then I was out of town until last night. Just now I came in to park my other car and noticed a little reddish brown fluid pool on the garage floor by the right rear wheel (see pics). Is this F1 fluid? My car is a converted manual, so I'm not exactly sure of what fluids are involved where. I couldn't see anything leaking when I looked from the top inside the engine bay.
    Any idea what this is and what is required to fix it? My quick search led me to both an easy fix of just draining the overflow to don't turn on the car it may erupt in a fire :)
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,952
    The Cold North
    Tom
    Is your e-diff still functional after the conversion? If so..this could from the f1 fluid being over filled and leaking out of the over flow tube. But have it checked regarless
  3. oc23
    oc23 Formula Junior
    459
    Rob Yo
    Yes, the e-diff was retained. Should I try to follow the bulletin posted in this thread? Sounds like the same issue this guy had: https://www.ferrarichat.com/forum/threads/f1-fluid-overflow.622041/
    Not sure where I get that little tool pipe though.
  4. Mario Andretti
    Mario Andretti Formula 3
    1,776
    Boston
    Without the F1 system, it is unlikely that an overflow is caused by too much fluid sitting overnight... Ediff won't cause that, not usually. Take out the diffuser and look for the source of the leak. Most likely leaking from one of the plugs (where the F1 used to be) or some hose broke. Or some of the connection fittings.
    If they used F1 fluid style in the clutch it could also be the clutch fluid leaking from the bleed valve... Don't drive it anymore.... it could be one of 29.5 things.
    RobinMasters and oc23 like this.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    You should easily see if fluid is coming from the overflow tube or seeping from the diffuser ..if leaking from overflow tube that sticks thru diffuser and diffuser is clean ..then we need to look at why the fluid overflowed .. we will open the little panel on engine bay and measure it
    Send me a PM with your number if you like and I will have a 10 min call with and we can get to the bottom of this
    oc23 likes this.
  6. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Overfilling can cause this and the problem only becomes known when the engine bay gets hot.
    Another issue can be an air leak further down the system, co check the E-Diff hoses and bleed nipples.
    Also, it looks like your fluid is due a change - it should be bright red (even accounting for the floor dirt).
    LorenzoR and flash32 like this.
  7. Finpat
    Finpat Karting
    Sep 17, 2021
    249
    Finland
    Kari Lehtinen
    First off, I am not F430 expert in form or fashion. That being said, is your car Spider? If that is the case, could the leak be from roof hydraulics? The colour of leak is similar to hydraulic fluid used in 360 Spider. Or at least in my 360 Spider.
  8. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    You don’t need the little pipe tool. It’s way easier to just stick your index finger into the reservoir until it touches the baffle inside. The fluid level should be halfway up your fingernail.
    Talk to flash32, he’ll walk you through the whole process. It’s very easy, just intimidating the first time.
    oc23 likes this.
  9. oc23
    oc23 Formula Junior
    459
    Rob Yo
    Thank you. PM sent. From what I can tell with my untrained eye (and reflected in the first picture I attached), the liquid seems to be gathering on the diffuser, then dripping from the diffuser to the floor. But again that's just my take of it.
    The odd thing is I've gone on very long drives (over an hour) and never had an issue, yet this started after taking the car on a 1 mile run and then leaving it for a few days. Thanks on the tip for the fluid change. My indy who just put back my stock exhaust mentioned I should just do it at my next service, but it maybe wouldn't hurt to do it earlier.
    It's a coupe, so that rules out the hydraulics.
  10. LorenzoR
    LorenzoR F1 Rookie
    Not sure if this was said yet but even though it's not a f1 car anymore, the ediff and f1 shared the same reservoir that's back up in that side of the car and it could still possibly overflow if overfilled. And yes as Mark says the oil looks kind of dirty
  11. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Did the longer drives happen over faster roads, and the shorter drives in slower/built up areas encountering more stop/start traffic?
  12. oc23
    oc23 Formula Junior
    459
    Rob Yo
    I don't think anyone mentioned it specifically, but that was something I realized it could be after finding that thread I linked in my post above (#3).
  13. LorenzoR
    LorenzoR F1 Rookie
    Very easy to check. Remove the small engine compartment panel four screws and you're there
  14. oc23
    oc23 Formula Junior
    459
    Rob Yo
    From what I can remember, my last few drives were (most recent first):
    Wed - drove to neighbor's house 0.8 miles away and back. Residential area so small side streets and a few stop signs.
    Tues - drove to get dry cleaning. About 4 miles away, few stop signs and red lights, lots of 50 mph + driving.
    Before that were a few drives a few miles each taking people for rides, and then a long drive to a cars and coffee through mountain roads about an hour each way.
  15. oc23
    oc23 Formula Junior
    459
    Rob Yo
    Alright, so this thing looks way overfilled? I know flash32 is going to walk me through it, but since it was easy enough to remove the side panel and unscrew the reservoir cap I thought why not. See this quick video, it is filled to the brim and the cap even has some liquid on it (a few drops fell into the engine bay, I wiped it off with a dry paper towel). Also you can see where it's dripping on the diffuser I think, the darker "wet" part from the top view matches where it is dripping from underneath.
    Video: https://www.dropbox.com/scl/fi/p1m0o366xoyfy5prc5vvy/Video-Jun-11-2024-8-34-32-AM.mov?rlkey=800mz9l8i4neja5w1p8hvki64&dl=0
  16. Mario Andretti
    1,776
    Boston
    Way overfilled. Remove some of that stuff and leave about an inch from the white plate at the bottom. It is also very dirty from what i can see; make sure you flush it soon. You will need to bleed the ediff to flush, now that you don't have an F1 anymore...
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    #17 flash32, Jun 11, 2024
    Mario
    As you know but wanted to make it clear here for any newbies
    That measurement is right after the pump just finishing running ( 6mm from plate/ .25 in) .. as the pressure is relieved the fluid rises .. so measurement will not be accurate unless done right after pumps stops with key in
  18. oc23
    oc23 Formula Junior
    459
    Rob Yo
    I thought since it was converted there is no more pump? In any event, I definitely won't do anything until I hear from you flash, since I am definitely a newbie.
  19. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    Whether a converted car or a factory car - a pump exists for the e-diff
  20. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Yes it’s way overfilled. You probably don’t have a leak, it’s just puking out of the overflow hose on the reservoir cap. If it’s hot outside and you drive it that will cause the fluid to expand and overflow, when it didn’t before when it was cold outside.
    Get a turkey baster and put a short length of hose on the end. You’ll need to suck out a couple inches at least from the reservoir, depending on if the pump has ran recently. Follow flash32’s advice for pump on/off fluid level.
    And yes, get the fluid changed. It should be bright red.
    RobinMasters likes this.
  21. oc23
    oc23 Formula Junior
    459
    Rob Yo
  22. LorenzoR
    LorenzoR F1 Rookie
    that looks ok in the glass but hard to tell. put some side by side so you can compare till you get it nice and clean looking
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    #23 flash32, Jun 11, 2024
    The best way is to put a few drops on a white paper towel and let it spread out ( 1 or 2 mins).. we can look how it spreads and color on paper towel after that time - take pics before and after time
    From the pics it looks ok to me - doesn't really mean much
    You can smell it as well
    Smell, color on the towel and how it spreads on paper towel is key
    oc23 likes this.
  24. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Looks well used to me
  25. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Pour an equal amount of new fluid into a clear glass and put them side by side, like was recommended in an earlier post. I think you’ll see that your fluid is slightly discolored.
    When I changed and flushed my F1 fluid, flash32 recommended that I use Mobil1 Synthetic ATF. That’s been in the system for about 3 years and it’s working great.
    flash32 and oc23 like this.
