fluid level check in 308 transmission | FerrariChat
Discussion in 'Technical Q&A' started by cavallo_nero, Nov 15, 2004.
  1. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    i searched the archives, but could not find info on how to check the fluid level in the 308 tranny. let me know.
    john
  2. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    remove the fill bolt and put your finger in the hole. The fluid should be at bolt hieght.
  3. Steve Magnusson
    26,772
    Check the figure shown in the "Lubricants and Liquids" section of your OM -- as Matt said, it should be up to the bottom of the fill plug treads.
  4. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    And, the car must be level.
  5. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    thanks guys.................john
    my finger and the car will be on the level
  6. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    #6 Peter, Nov 16, 2004
  7. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    thank you for the picture Peter, that helps a lot.
    john
  8. PeterS
    PeterS Five Time F1 World Champ
    52,036
    Goodyear, AZ
    PeterS
    When I last filled the gearbox, I swore the car was dead-level. I racked it a week later (It was level then!) and I pulled over a half quart out!
  9. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    Hey Peter, i did not realize you owned a euro 308, is yours a GTS, mine is a 78 Euro GTS. i have synthetic fluid in the gearbox, i cannot remember what i used way back when. what are you using in there??? do you remember the allen wrench size for the inspection/fill hole?? thanks again. i have a jiffy lube nearby that lets me use their bay for alll my fluid changes - and they do not charge me for it - too cool, as long as i bring in my own fluids. i think they like the attraction my car draws while it is in the bay........
  10. jongottschalk
    jongottschalk Karting
    Oct 5, 2009
    171
    Pass Christian, MS
    Jon Gottschalk
    12mm for inspection allen. You can see it on the photo on the socket....
  11. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    sounds like you've got bad shift shaft seals.
    it allows motor oil into the tranny.
