fluids and maintenance question for TR | FerrariChat
Discussion in 'Boxers/TR/M' started by Nick_Fl, Mar 3, 2008.
  1. Nick_Fl
    Nick_Fl Rookie
    Jul 10, 2006
    16
    Fort Lauderdale, FL
    Nick
    All,
    What oil do you recommend for the engine and tranny for a 86 TR?
    Also, how to get to the expansion vavle for the AC unit. I took the fuse box out and I can't get to it....any idea?
    Thanks,
    Nick
    Fort Laurdale
  2. sparky p-51
    sparky p-51 Formula 3
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    Redline 5W40 for the eng and Redline 75W90NS for the tranny. Dunno about the expansion valve. Someone will be with you soon I suspect.
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,368
    Frederick, Maryland
    Brian Brown
    You must remove the dashboard and A/C evaporator housing to get to the expansion valve, since it is located inside the housing. Typically the screen in front of the expansion valve gets plugged up with debris over the years, sometimes from a receiver-drier that the desicant is leaking out of.
    You can use an A/C flush kit and compressed air to backflush the valve. Just disconnect the lowside hose (SUC) at the compressor and the hose as the receiver-drier. Flush the expansion valve from the rear of the car, and have a helper catch the fluid/debris at the front. Keep flushing until no more debris comes out.
    You will have saved yourself about 20 hours of labor. After flushing, replace the receiver-drier with a new one.
    Good Luck!
    Brian Brown
    Patrick Ottis Co.
  4. PSP
    PSP Formula Junior
    Mar 31, 2001
    603
    Lake Forest, CA USA
    Patrick S. Perry
    Excellent advise.
    Many of us have solved the "clogged expansion valve" issue this way without taking the dash out.
  5. Nick_Fl
    Nick_Fl Rookie
    Jul 10, 2006
    16
    Fort Lauderdale, FL
    Nick
    I looked at my expansion vavle today. IT is outside of the AC evaporator box. I can see it from both inside the car (passenger side - cowl) and the trunk (fuse panel removed). From what I can tell, it is not an orifice type expansion vavle but rather one with the spring mechanism inside (it has a temp tube that runs inside the car). Can those vavle be backflushed? According to my workshop manual on a CD, there are 2 different types of expansion valves.....
    Also, one of my window is slow and the other is broken. Is there a generic motor and regulator parts or should I buy then from Ferrari. Any contact for aftermarket parts other than Ferrari?
    Last but not least, I replaced the alternator 8 months, 200 miles ago and the light just came on again. Battery is good. Is there a relay to check or what gives?
    Thanks and happy mortering.
    Nick
  6. Motob
    Motob Formula 3
    Nov 11, 2003
    2,368
    Frederick, Maryland
    Brian Brown
    The search button above is your friend.
    See: http://www.ferrarichat.com/forum/showthread.php?t=163100&highlight=tr+expansion+valve
    http://www.ferrarichat.com/forum/showthread.php?t=52375&highlight=tr+expansion+valve
    http://www.ferrarichat.com/forum/showthread.php?t=58351&highlight=tr+expansion+valve
    http://www.ferrarichat.com/forum/showthread.php?t=44288&highlight=tr+window
    On the alternator, If the light is on, then most likely there is a problem with the alternator or voltage regulator (which is part of the alternator). You can check the power and DF connections at the alternator, if they are ok, then it's time to remove it and have it checked out.
    Brian B.
  7. PSP
    PSP Formula Junior
    Mar 31, 2001
    603
    Lake Forest, CA USA
    Patrick S. Perry
    Nick, mine is an early 1988TR, so it probably has the same receiver/drier - and honestly, you have absolutely nothing to lose.
    I bought a quart of the flush stuff at Carquest, about 3 feet of each size of clear plastic tubing to fit over the fittings at the compressor. Take the hoses off the compressor and the receiver/drier, put the hoses over the ends at the compressor and run them each about 12" into a gallon milk jug. Pour as much of the flush fluid into each hose at the receiver/drier and let it sit for a few minutes, then force the flush liquid through with an air compressor with one of the tips you'd use to dust off a countertop. If you can, do it several times, then blow it out really well to get everything out. Reconnect the compressor and install a new receiver/drier.
    The receiver/drier is available from Ferrari or if you can live with it not having Ferrari stenciled on it, you can get an identical one for a Saab - details here: http://www.ferrarichat.com/forum/showthread.php?t=58351&highlight=tr+expansion+valve
    Window-wise, the first thing to do is take the switches out of the center console and give them a healthy bath of contact cleaner. That might take care of the slow one - if not, the next step is to remove the motor and clean the grease from the top which forms a concrete-like compound. The relay setup is normally the final solution, but try the easier ones first.
    Here is the TR cross reference list: http://www.ferrarichat.com/forum/showthread.php?t=125008
  8. Steve Magnusson
    26,823
    On the alternator, also have a look at the mechanical/belt system during operation (two different designs were used -- early = V-belt = some troubles, and later = multi-rib belt = better). If that seems reasonable (e.g., the belt is still there and things are turning ;)), measure the voltage across the battery terminals at say 2000 engine RPM -- if only ~12V, it quasi-confirms that you'll need to go deeper into the alternator electrics (and the warning light illuminating isn't indicating a false problem).
  9. johng
    johng Formula 3
    Oct 23, 2004
    2,298
    northern va
    john g
    for oil, try something that still has zinc in it. i think i use Motul in mine. and redline 75-90 for gear oil.
  10. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
  11. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Ok, I'll go next: when my trany was repaired, the shop recommended shell spirax gear oil sae 75-90 for the tr. My next oil change will be lubrication engineers 8800 sae 15w40 (loaded with zinc) www.le-inc.com and what they said about the checking out/fixing the alternator inthe archives. Good luck!
    Jeff Pintler
    89 348tb, 86tr
  12. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    You want more than just Zinc and not just Zinc with some Phosphates thrown in. You need the compound ZDDP. Zinc dialkyl dithio phosphate. http://en.wikipedia.org/wiki/ZDDP
    There are a lot of additives out there that are posuers because even though they have zinc and phosphates in them it is NOT ZDDP.
    http://www.zddplus.com/
    REDLINE oil for me!
