Flush needed Changing Mineral to Synthetic Motor Oil? | FerrariChat
Discussion in 'Technical Q&A' started by UroTrash, Aug 22, 2009.
  1. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
    I'm changing my 2005 Tundra (60,000 miles) from Castrol 5W30 to Mobil 1 5W30 in order to increase the oil change interval from 5,000 miles to 10,000 miles.
    The truck holds 6.5 qts.
    I thought what I'd do is drain the old oil, change the filter, add 5.5 qt of Mobil 1 (low end of dipstick marking) as a flush, run it for a few minutes, drain that and put in 6.5 qts fresh Mobil 1.
    Do you think the flush is necessary in changing mineral to synthetic?
    The flush would cost $25 in wasted oil, BTW.
  2. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #2 finnerty, Aug 22, 2009
    Most parts guys and techs I've asked insist that a proper flush (with a specific flush additive) is vital in order to change over to synthetic motor oil.
    Personally, I have never made the switch in any of my vehicles so I've never tried to "disobey" their advice. Though, I doubt that I would, as it is fairly simple to do a proper flush. Yeah, you waste some oil and spend a few extra bucks, but you only have to do it once.
    So, it seems worth it rather risking any potential problems from not doing it properly.
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,389
    Frederick, Maryland
    Brian Brown
    You will just be wasting perfectly good oil. just change the oil and drive the car. If you are worried that the oil will not perform as well, as if it had 100% Mobil One in it, then change the oil at 7,500 miles. Then the next oil change you can go to 10,000.
  4. JCR
    JCR F1 World Champ
    11,041
    H-Town, Tejas
    You are getting scammed by know-nothing parts guys and techs.
  5. normv
    normv F1 Rookie
    May 3, 2005
    2,767
    Mishawaka In
    Norm
    Hello, seems like a waste to me, then it may depend on the mileage of the engine. Now I now hes just talking about a simple oil transfer, but Ive used the flush where you let it run for 5 min. in a can on a high mileage truck, turned out to be a disaster plugged everything up oil valley and pump screen.
  6. finnerty
    May 18, 2004
    10,406
    What a shock! LOL..........wouldn't be the first time that the "self-proclaimed experts" in the auto business were full of BS :)
  7. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I'd run the Mobil for about 2,000 miles and then drain again.
    After that you can go to 7.5K-10K mile intervals.
    A quick flush will do little. You need to get the oil to flow and to temp for it to have any cleansing effect.
  8. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
    Thanks guys, glad we settled that!
  9. Earthboundmisfit
    Earthboundmisfit Formula Junior
    Aug 7, 2009
    886
    Ontario
    Steve
    Is this actually true though? I've been told otherwise. Synthetic oil gets dirty just as fast as mineral oil, the difference, I was told, is that synthetic provides better protection at higher temperatures. So you shouldn't necessarily be extending the time between changes. Also heard that it isn't good in older engines so I stopped putting it in my BMW. Don't know if this is true or not but I just couldn't justify the significant extra expense when the benefits were not definitive.
    I'm new here, I'm guessing this is a topic that's been discussed extensively in the past. I need to do a search on it. I'm not doubting synthetic is better, but I'm not sure it's necessarily better in every vehicle or to allow for fewer oil changes.
  10. rbf41000
    rbf41000 Formula Junior
    Nov 21, 2005
    698
    Delray Beach FL
    Russell
    Some motor cycle engines would come with std oil for break in and be changed to synth at 1st service, don't think they did anything exept drain change filter and refill.
    Russell
  11. davem
    davem F1 World Champ
    11,004
    Stepford, Connecticut
    dave m
    There are many oils on the market that are a combination of mineral and synthetic already to help you in this transition.
    Sorry couldn't resist
  12. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    If you are actually concerned with the change over, all you really have to do is to fill it up with synthetic, drive it for a couple thousand miles, then change it again. You get to choose when to change it again based on $$$ wersus fretting.
  13. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
    I'm thinking the flush is a waste of time/money as well.
    Doesn't say anything about any disaster mixing M-1 with the last qt of Castrol left in the nooks and crannies.
  14. tazandjan
    39,318
    Uro- Should cause no harm. I had four new Jeeps and always changed them over to Mobil-1 after they had 1000-1500 miles on them. Just drain the old oil when hot, change the filter, add new oil and you are good to go. I always change my oil at 5000 miles or one year intervals anyway, and the small amount of conventional oil left in the nooks and crannies will not cause any problems. Your truck holds way more oil than the Jeeps, so the oil will be purer than it was in my Jeeps.
    Taz
    Terry Phillips
  15. Rifledriver
    37,288
    It is required by Federal law that ALL motor vehicle motor oil be compatible.
    You can mix synthetic and dinosaur oil quite safely.
  16. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
    #16 UroTrash, Aug 23, 2009
    ^^ thanks guys!
    BTW, I know I started it....I'm good on "nooks" but I admit I'm not sure what a "crannie" is.
  17. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
    I would enjoy hearing comments about Professor Haas's narrative in his Oil 108:
    I get the impression, that for 10 seconds, the machine had no lubrication. I'm having a hard time imagining an oil expert doing this. It's not at all like the initial assembly where everything is gooped up with zinc. It almost sounds like he preferred the engine running without any lubrication to the 2 synthetics missing! What am I missing?
    http://ferrarichat.com/forum/showpost.php?p=136399317&postcount=1
  18. tazandjan
    39,318
    Uro- Actually, you work in crannies, so here is an increase in your professional vocabulary with which you can impress your clientele.
    Main Entry: cran·ny
    Pronunciation: \ˈkra-nē\
    Function: noun
    Inflected Form(s): plural crannies
    Etymology: Middle English crany, from Middle French cren, cran notch
    Date: 15th century
    1 : a small break or slit : crevice
    2 : an obscure nook or corner
    Fits really well with what you do, no?
    Taz
    Terry Phillips
  19. UroTrash
    Jan 20, 2004
    40,698
    Purgatory
    Clifford Gunboat
    LOL, yes Terry, that is exactly right.
    Cranniologist.....a ring to it!
  20. tazandjan
    39,318
    Uro- Eminent cranniologist. You are right on Dr Haas. He did a lot more damage doing that than leaving a little Shell in the oil lines.
    Taz
    Terry Phillips
  21. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    Back when I got my 1st new car in college, a friend told me to run the car for few seconds with no oil fiilled in every oil change to make sure all the old oil are completely drained, but I never listened to him. That guy later on lost his oil drain plug on his Rambler on a drive to school, his engine seized up.
    As for the new car that got in college in 80's, I put Mobil 1 synthetic in it from the 1st oil change, the last time I heard is someone was still driving it with some 300,000 miles on clock. Back then a quartz of Mobil 1 cost around 3 bucks, it was expensive for a poor student, but I changed oil every 10,000 miles or so.
  22. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    It seems to me that for street-driven engines the only clear advantage of synthetics is that they have wider viscosity ranges--- so they flow better at startup. With a really expensive engine it therefore might make sense to use it.
    But, yes, they get dirty just as fast. So unless you are doing those 10,000 miles in long journeys on freeways without a lot of dust around, you will need to change it before 10K anyway.
