Flushing F1 Fluid on 430? | FerrariChat
Discussion in '360/430' started by caymangone, Jan 16, 2019.
  1. caymangone
    caymangone Karting
    Jan 13, 2017
    79
    Missouri
    I've performed the annual maintenance on my F430 for the last two years and managed to change out every fluid in this car except for the F1 fluid. Now that I have a Launch x431 pro diagnostic tool, I'd like to flush the system on this next maintenance go-around. I found an excerpt out of the manual for a "System Bleed" 3.04 that looks like a decent way to do what I want to do. They talk about two unions, one down near the oil filter, and the other "on the block for the clutch pipe rapid coupling" which I found to disappear behind the right engine bay panel. My questions are, are these unions they way to flush the system or at least replace most of the F1 fluid and if so, any preference which? Also, they use an SD-3 for the bleed procedure in the manual. What is the function on the X431 for the bleed? Another obvious question from a newbie is why do you even need a diagnostic tool? Couldn't a person simply open one of these unions while the F1 pump is running (opening the driver's door?)? Isn't the system under positive pressure and by opening a union, fluid will flow out, dropping the pressure to the point the F1 pump kicks on?
    Of course I know during this whole process, you want to keep the reservoir full. Thanks for any insight! Great to belong to a group of knowledgeable folks that aren't afraid to work on these cars!
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,949
    Central NJ
    Dominick
    Let me see if I could answer your questions
    All depends how complete you want to flush the system - not bleed
    If you know there is no air ( no known shifting issues etc) in the system a complete bleed is usually not necessary
    In terms of flushing - there are various degrees you can do
    You can just suck all the fluid out of reservoir behind panel and replace with new fluid - do this a few times with some driving in between
    You can bleed from top bleed screw that go to e-diff on block near tank - this will flush tank and actuator - the system will have pressure it so just open and close keeping fluid topped off - you can put some extra fluid in before starting so you don't low
    you can do a total flush and bleed if you do the bleed in the manual for clutch , actuator and e-diff
    I don't think the x431 does a e-diff bleed - but it does have clutch and actuator bleed
    Be aware to bleed the actuator you will have to remove it (leaving lines on ) and loosen screws - I think the cat may have to come off on a f430
    Choose which level you want to perform - considering how long it has been since it was done and if you are having any issues with shifting, jumping to neutral, long running , freq running of pump
    Hope this helps
  3. caymangone
    caymangone Karting
    Jan 13, 2017
    79
    Missouri
    Thanks Flash 32. No issues with shifting or jumping to neutral. I did follow a thread pertaining to the bleeding of the actuator which is only an internal bleed and does require the removal of the actuator to get to the three screws. But since it's an internal bleed process, it won't remove the fluid so I'm back to the other options. From what I've understood from another thread, you're not able to remove enough fluid from the reservoir to do any good due to a disc inside. Some have attempted to snake around the disc with a small bent tube to get under the disc but not sure how effective that is. The external bleed screws seems to be the only good option I can see. The only other concern is not knowing what fluid is currently in the system and using a compatible fluid since I'm not going to be able to entirely flush the system with just the external bleeding method. I see that Tutela CS speed fluid is a good fluid to use but again, not sure of compatibility.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,949
    Central NJ
    Dominick
    The idea of flushing the actuator is that once you put new fluid in tank by flushing it from the clutch is to work the new fluid into the actuator and bleed any air. Yes the fluid, with screws open, will flow back to tank but new fluid will be in the different cambers of actuator and any air will be pushed out. Then the tank would be flushed again you bleed the e-diff ... not 100% every drop but pretty close. The only way to get every last drop is to disconnect items and drain fluid completely and then do a full and bleed ... i would not recommend this since you are asking for trouble especially that you are not having issues
    I would do the clutch bleed , then the block near tank ( top) that goes to quick disconnects to ediff ( since you cann't bleed e-diff with x431 ( please check that)) and if you want / need bleed actuator in between the those 2 steps.
    I had a typo above which I cannot edit now - this "You can bleed from top bleed screw that go to e-diff on block near tank - this will flush tank and actuator" shoud have said You can bleed from top bleed screw that go to e-diff on block near tank - this will flush tank and accumulator"
    Do you know what type of fluid is in there now - any record of someone changing it - what color is it - clear/green/red
    Tutela I believe is clear, CHF is greenish
    If it is Red ( most likely factor fill or changed with same product) - I had done quite a bit of research and found that Mobil 1 sync ATF seem to be a good sub for the Shell product ( close to/same specs)
    All that aside with engine off for a while ( over night) .. after taking panel off on right side .. open tank I think you can get a fair amount of liquid out - try that first since it is easy
    If you are up to it ...bleeding/ getting new fluid into actuator is probably one of the most important things to have done if never done since it is a dead end and the actuator puts stress on fluid
    Was the fluid ever flushed / bled since new?
  5. tazandjan
    39,187
    Ferrari finally figured out the F1 fluid should be changed, system bled, leak check done, and self-test performed every 3 years. Never made it into the F430 maintenance schedule, but here it is in the 599 schedule from 2007 onwards. If anything, the F1 fluid sees much rougher duty in the hot spaces of the F430 than it does in the 599.
  6. Fenz
    Fenz Karting
    Nov 8, 2018
    176
    Team Europe
    Would be nice if you could write a summary in this thread when you have completed the fluid change.
    I'm about to do the same later this year and I also have an x431 Pro.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Is the fluid clean in the pot ? My dealer says to leave well alone if working ok
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,949
    Central NJ
    Dominick
    Terry
    I would be curious of how the WSM says to flush and bleed the 599 ..any way you can post those few pages ?
    Thanks Dominick
    Sent from my moto x4 using Tapatalk
  9. tazandjan
    39,187
    Dominick- Will take me a while to unlock the WSM. Probably not for a couple of days.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,949
    Central NJ
    Dominick
    Thanks appreciate it
  11. Flyingbrick242
    Flyingbrick242 Formula Junior
    677
    Northern AZ.
    Gentlemen,
    Lots of excellent advice mentioned above: I recently performed a annual fluid change of all fluids in my F430...I was strongly advised by a factory trained Ferrari tech to not bleed the system if: like mentioned above your shifts are free from errors and no warning messages displayed instead remove old fluid from reservoir [should be very red in color] and replenish with new...perform this a few times and your good to go....This worked for me...and I have the Launch X431 pro.
    Good Luck..!!
  12. tazandjan
    39,187
    I change out half the fluid every year and do the complete change every 3 years. Not too sure I would trust a mechanic who says to leave F1 fluid in for extended periods of time. Do they say the same thing for brake fluid or power steering fluid?
    flash32 likes this.
  13. caymangone
    caymangone Karting
    Jan 13, 2017
    79
    Missouri
    Trying to get the records from the last ferrari service center to see what was done on it as the original service records weren't with the car. If I can find out what's in it for sure, I may just do the top bleed screw flush a couple times for the next couple of years. As was the concern by others, I'd rather not take the chance of screwing something up that isnt broke. The nearest Ferrari tech is 3 1/2 hours away.
  14. Flyingbrick242
    677
    Northern AZ.
    It is never acceptable to leave hard working fluids in for extended periods of time not limited to brake and power steering, I believe the point here is from the professional perspective based on experience if your F1 system is working perfectly and your fluid is fresh red in color it’s safe to say it has not been subjected to overheating removing the fluid from the resevouir once or twice per service is perfectly acceptable....once a year like you mention and complete flush every three years would not be a bad idea..
  15. FSM348
    FSM348 Formula Junior
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    Did anybody end up using the x431 pro to properly flush the F1 fluid? I’d feel much better replacing a large amount of fluid in one go rather than 20% at a time. It would take an exponential amount of 20% changes to replace a good portion of the fluid and much more time wasted IMO.
  16. tazandjan
    39,187
    You can take nearly 50% of the total fluid out of the tank without introducing air into the system. Does not answer your question on the x431 pro since my techs use AutoEnginuity to do the full fluid change and bleed. That is a bit more expensive.
  17. 24000rpm
    24000rpm F1 Rookie
    for your information, here's my fact.
    I did not replace my f1 fluid in my 360 challenge in about 6 years already. And it still shifts ok.
    LOL
  18. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    So you can get 1L out of the reservoir? Am I correct that the top bleeder near reservoir and the bleeder near the E-diff are the only two needed to operate in order to exchange the fluid?
  19. tazandjan
    39,187
    24000, yup and there are folks running around that have not changed their oil in 6 years, too. Proves nothing except you have been lucky.
    348, forgot about the F430 E-Diff holding more fluid. You can get about 1/2 liter out of the tank. For F1 Ferraris without E-Diff, that is about half.
  20. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    Thanks for the info taz. One last one, anything wrong with just turning pump on with launch software (or whatever software one chooses) and bleeding the system through the highest bleeder next to reservoir while adding new fluid into reservoir to keep it from running empty?
    I also plan on pressurizing system to 52 bar then cycling 12 volts to the e diff solenoid until there is no pressure in system after flush is complete.
    24000, there are many more reasons to flush the F1 system fluid than not. It apparently gets contaminated over time and there are plenty of very tight tolerance mechanical parts that can get damaged. I’m using Stef’s advice and using Liquid Moly Central Hydraulic lubricant instead of what factory used. He brought up what I believe to be good points why this is a good idea and possibly the best lubricant specifically for our F1 systems.
  21. tazandjan
    39,187
    #21 tazandjan, Apr 12, 2020
    348- Juri made a separate pump to pressurize the system so it could be bled without a diagnostic tool. My techs used that way back when until I bought them AutoEnginuity.
    One of the pros is a better candidate to answer your question on your bleed technique. I still use Tutela CS Speed, now by Petronas, in mine. It was designed for Selespeed applications. Hard to find and $50/liter, but when I do find it, I pick up a few bottles. Has worked well for the nearly 12 years I have been using it.
  22. Jgivoo
    Jgivoo Formula Junior
    437
    New Jersey
    On my 2008, you will only get approx 100ml from the reservoir. There is a plastic plate internally and almost impossible to remove any fluid below the plate.
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,949
    Central NJ
    Dominick
    Look here ..I think you will have all your answers .. look around post 24
    The x431 will not allow you to bleed the e-diff .. you will need a controlled power source ...but read this post and let me know if you have any questions
    I made comments on the thread
    https://r.tapatalk.com/shareLink/topic?url=https%3A%2F%2Fwww%2Eferrarilife%2Ecom%2Fforums%2Fshowthread%2Ephp%3Ft%3D59647&share_tid=59647&share_fid=38220&share_type=t&link_source=app
    Sent from my moto g(7) using Tapatalk
  24. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    Thanks, read that whole thread. I changed the system fluid by opening the upper bleeder near the reservoir. Am I missing any fluid in the Hydraulic system? My understanding is if bleeding out air then it goes Diff bleeder, bleeder 2 then bleeder 1 as mentioned in the linked thread. Finally the actuator is bleed.
    But if your just changing fluid then shouldn’t using the single bleeder near the reservoir completely flush the system?
  25. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,949
    Central NJ
    Dominick
    The only dead end line is the clutch line so.. if you flush that and that bleed nipples that was discuss in thread you will get most of the fluid out and the remaining ( in actuator and in ediff) will get mixed in with normally driving
