Flywheel and Cam lock tool | FerrariChat
Discussion in '456/550/575' started by Prit Singh, Nov 21, 2018.
  1. Prit Singh
    Prit Singh Karting
    May 29, 2017
    96
    London
    Hello
    I have been recently looking into a flwwheel lock tooL for the 456.
    I have seen the vice grip method for the cam pulleys and as a Last resort will use this.
    I was at Hill Engineering to buy some bearings and asked whether their flywheel tool (AV3546) for the 550 would work on a 456 and they couldn't find any info on this.
    http://www.hillengineering.co.uk/95973546-av3546-
    Has anyone got any experience with this tool and weather its good for a 456GT?
    Also Is there a tool to lock the Cam pully's?
  2. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Ferrari manual calls for vice grips. Pulleys are metal and can easily take the stress. Dealers do it this way. VG leave plenty of room to work. In my opinion vg is best option. Not sure why you would want to do it another way?
    Just because it’s cheap?
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Vice grips are barbaric - they side load the pulleys, scratch the finish, etc. Make something from wood to get the job done.
    Prit Singh likes this.
  4. tazandjan
    39,163
    Works on the 575M and 612, but I would send an e-mail to Paul Hill and ask about the 456 GT. The only thing the flywheel lock is used for is removing the crank nut without having to use an impact wrench, but that alone is very worthwhile.
  5. franschman
    franschman Formula Junior
    Dec 18, 2017
    362
    Holland
    Bart
    #5 franschman, Nov 21, 2018
    wrong topic, message deleted.
  6. Prit Singh
    Prit Singh Karting
    May 29, 2017
    96
    London
    Hey I did email you guys about your 355 cam lock tool and If it can be adapted to the 456GT. It wasn’t compatible I was told. It would great If you could consider making this tool as It would work on many models.
  7. Prit Singh
    Prit Singh Karting
    May 29, 2017
    96
    London
    Thanks will email or visit them as they are 3 miles away from where I live.
  8. fatbillybob
    Aug 10, 2002
    28,980
    socal
    I have worked on 100's of cars and just about every model of Ferrari prior to 2004. I have never needed a cam lock tool, vise grips for that job, or flywheel locking tool.
    brogenville and Prit Singh like this.
  9. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I have some ideas for a new tool however it's not high on the list at this time.
  10. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,151
    Bay Area Calif.
    Dave
  11. jcbam
    jcbam Karting
    Nov 30, 2019
    79
    New York
    do you mind to share your experience on how to do it with those tools? appreciate your inputs!
    Qavion likes this.
  12. jcbam
    jcbam Karting
    Nov 30, 2019
    79
    New York
    I solved my own problem. I did the starter bump method and got the crank bolt loosen quite easily.
    Sent from my iPhone using MotorInteractive.com mobile app
  13. Rifledriver
    37,089
    Same flywheel tool for all.
    Why a cam lock tool? Cam isn't going anywhere. It isn't a V8.
  14. plip
    plip Formula Junior
    Aug 25, 2003
    292
    Switzerland
    Gianni Olivieri
    Hi Brian,
    actually have to loose the cam pulley bolt. Have to remove the front cover and the lower drive to chase the 'usual' rattling noise and after that am afraid timing check will be unavoidable. What's the best way to lock cams to remove the bolt ? Incidentally , and since the rad is still the car, have not enough space to use an air impact wrench since mines (2) are both too big.....
    Tks for any help on this matter
