Flywheel bolt replacement | FerrariChat
Discussion in '308/328' started by flyngti, Mar 8, 2010.
  1. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    In the middle of my clutch replacement, I realized my flywheel needs to be resurfaced. I'm planning on replacing my flywheel bolts when I put the flywheel back on.
    Questions:
    1) I've always been told to replace flywheel bolts. How necessary is this?
    2) The bolt head has "R12" and four lines (like a pyramid). I'm not familiar with this designation on a bolt. Can I just use a class 8.8 bolt from a local fastener shop? I believe they are 10x1.25x25.
  2. JV's89
    JV's89 F1 Veteran
    7,299
    Pittsburgh, PA
    I think those marks indicate that the bolts are grade 5 bolts (commonly available) but I've never heard of replacing them.
  3. Rifledriver
    37,105
    Reuse the old bolts. No one replaces them and you will be sure they are the correct ones..
  4. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    #4 flyngti, Mar 8, 2010
    Ok, good to know. Somehow I remember a voice from my early wrenching years to always replace the bolts, but I'm good with reusing as long as it's safe.
    btw, here are the markings on the bolt head.
  5. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    But if you do replace them, then personally I would reco using 12.9s.....
