Flywheel for a 355 CH | FerrariChat
Discussion in 'Technical Q&A' started by gatorgreg, May 8, 2008.
  1. gatorgreg
    gatorgreg Formula 3
    1,949
    NAPLES
    Greg Griffin
    Does anyone know where i can get a flywheel for a 355 CH for less than $4k? Or has replaced their 355 CH flywheel with some other product?
  2. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    A custom one would likely be higher quality, lighter and definitely cheaper. Contact AP Racing or Tilton.
  3. gatorgreg
    gatorgreg Formula 3
    1,949
    NAPLES
    Greg Griffin
    Let me start over. I have a 355 Ch 1995 and I am having some problems with clutch slippage. The reason is oil is getting into the clutch housing. What should I do? My local mechanic said I should replace the flywheel to resolve this problem.
  4. chrisx666
    chrisx666 Formula Junior
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    What sort of oil? Could be gearbox oil (shaft seals leaking) or hydraulic fluid (slave cylinder leaking). It's an easy job to remove the clutch housing and have a look rather than guessing and buying a new flywheel.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Take your mechanic out back and punch him in the belly.
    Most leakage is cured with new seals (or throwout bearing), not a new flywheel!
  6. F512M
    F512M Formula Junior
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    +1 Find a new mechanic.... That is unbelievable....
  7. fatbillybob
    Aug 10, 2002
    29,252
    socal
    +1 that's funny...
  8. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    #8 PAP 348, May 8, 2008
    Your backyard mechanic is smoking crack!! :eek::eek:
    There seems to be a lot of mechanics out there smoking crack as of late. :rolleyes::rolleyes:
    Already great advice posted here. Remove the clutch pumpkin and have a look in there and see whats going on. :):)
