Flywheel O-ring question | FerrariChat
Discussion in '348/355' started by LmnsBlu355, May 1, 2010.
  1. LmnsBlu355
    LmnsBlu355 Formula Junior
    Dec 28, 2009
    284
    NY
    Jordan S.
    #1 LmnsBlu355, May 1, 2010
    Where exactly is the Oring marked 23 in the attached picture?? Is this Ferrari's depiction of the Oring on the shaft near the triple seals or is it sandwiched between the bearing and snap ring on the fly wheel. (I don't see it in my fly wheel. I'm assuming its the one on the shaft but need comfirmation).
  2. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    Well I've just taken mine apart and didn't see an o ring there. as you say, there is a snap ring.
    I just looked on diag with triple seals on it and couldn't see there the o ring, so possibly is.
    the only other o ring around there I can see is the big one on the flywheel.
    Whats interesting is they dont show that or indeed the bearing the other side of the flywheel, but i presume thats because the flywheel comes as a complete unit.
  3. LmnsBlu355
    Dec 28, 2009
    284
    NY
    Jordan S.
    #3 LmnsBlu355, May 2, 2010
    Andrew,
    Thanks for the reply. I removed the bearing and looked very carefully. No O-ring in that location inside the flywheel. I'm now sure its the o-ring on the shaft (See pic) that gets inserted into the flywheel assembly. When all is assembled, the oring sits deep to the bearing but remains in the groove on the shaft.
    Silly way to depict it in an exploede figure if you ask me.
  4. LmnsBlu355
    Dec 28, 2009
    284
    NY
    Jordan S.
    #4 LmnsBlu355, May 2, 2010
