Fob problem | Page 2 | FerrariChat
Fob problem
Discussion in 'Technical Q&A' started by Dr.B, Dec 6, 2013.
  1. Skidkid
    Skidkid F1 Veteran
    9,689
    Campbell, CA
    John Zornes
    Not off the top of my head and I think that it varies by implementation but I can look up what is standard. Headed out and can't get to it until Sunday but will post as soon as I can.
  2. taneshaleo
    taneshaleo Rookie
    Dec 19, 2013
    5
    Sounds like the battery has been flat for a long time and the rolling code has been lost
  3. tazandjan
    39,420
    Low batteries do not affect the rolling codes.
  4. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    Than TazandJan spot on. The contacts had corrosion. Cleaned up with new battery and it works spot on thanx again
  5. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I just found this thread. I've thought most guys with clones either keep the copy safely in some drawer and only pull it out in case the other is lost or rotate in and out frequently. I've sold my 360 and moved to the dark (Lambo) side so can no longer try things on my own car.
    Have we reached a consensus that the solution is to not use one more then three times without switching? Does the three presses in ten seconds not always work?
    I still program fobs, although not nearly as many because the big stash I had found ran out, and it would be nice to include some tips in the package.
  6. ssnowball
    ssnowball Formula Junior
    296
    Scot
    Hi there Mark, rotating the fobs (cloned and original) is the way to go. I neglected to do this for a while and was required to press the button on the one that I was not recently used close to 200 times to realign the code. Overall, a small price to pay for the insurance of an additional fob. I keep two key rings, each with a fob and a key and am now rotating use.
    Long term goal will be to obtain PIN and obtain a new 3 fob set from Ferrari. My particular car has had a number of owners, but I have a good set of service records that do not show replacement of the original ecu, so I am hoping that the original PIN from Ferrari will work.
  7. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Didn't Eric and Taz find a way to extract the pin from a data dump?
  8. tazandjan
    39,420
    Gobble- No, we never did.
  9. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    but you should :)
