FOH | FerrariChat
FOH
Discussion in 'Texas' started by buzz69er1980, May 8, 2007.
  1. buzz69er1980
    buzz69er1980 Rookie
    Jan 1, 2007
    21
    houston
    Paul
    So I just called fer. of houston to find out how much it would cost to put an x-ost on my 355, they said they could not put on after market parts and then I asked if they could recommend anybody and they said no..whats up with that...The only dealer in town, you would figure they would have more info..Can anybody help? Or can I do this job myself?
  2. BigTex
    79,368
    Houston, Texas
    Bubba
    Search here, Rifledriver posted the Notice from FNA telling the delaerships to "Knock it off" with aftermarket wheels and exhaust.....warranty is VOID if installed, so FoH is correct....
    Try Ferda over at Vintage Motorcars on Kempwood, or come over and me and Greg328 will bolt that thing on!
  3. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    Roro got an X-OST installed on his 360 recently at Progressive Autosports. Talk to him about it.
  4. ADON
    ADON Formula 3
    Feb 8, 2007
    1,059
    Or you could try Houston Lambo. I saw the sign out front says "Exotic Sales & Service". And I saw someone mention they actually have one of the best Ferrari techs in Houston.
  5. TexasMike
    TexasMike F1 World Champ
    Feb 17, 2005
    10,485
    Austin, Texas
    Michael C
    The memo:
    To all parts managers,
    Re: Use of Non-Genuine Aftermarket Parts
    Following an increasing number of vehicle failures and customer complaints concerning the fitting of non-genuine aftermarket components, I wish to bring your urgent attention to some of the possible consequences.
    FNA has observed more and more dealers becoming involved with the fitting of non-genuine aftermarket exhausts, different specification non-genuine wheels, Engine ECU "chipping" (i.e. re-programming), seat modifications, steering wheel changes and suspension ride height adjustments to name a few. Each of these has the potential not only to void a customer's warranty, but could also result in the dealer being held liable for possible product related issues.
    Examples of such potential problems include loss of airbag due to steering wheel replacement. Engine failure or malfunction, check engine light illumination, damaged catalytic converters, due to engine ECU reprogramming and or the fitting of non genuine aftermarket exhausts. Suspension failure caused by the fitting of different specification non-genuine wheels. Fender damage, uneven tire wear and handling issues caused by changing ride heights. These are just a few examples...the list goes on.
    As we have communicated to you previously. these modifications are strictly against Ferrari policy for cars under warranty. I am astounded that a dealer would carry out any of these modificationson any car of any age as the potential loss certainly outweighs the short term gain. The vehicles warranty book clearly states " The limited warranty does not cover misuse, negligence, overloading, or any type of modifications."
    The issue of exhaust systems is becoming more common since model year 05 cars have even more stringent emissions requirements and the threshold for setting errors is very low. We have cases showing (e.g. 4 Tubi systems in California last week alone) that with any exhaust modification, an error can be set in the engine management system and a check engine light will be visable on the instrument cluster. The long term effects include, but are not limited to, excessive engine heat, catalyst failure, incorrect air/fule mixture, and possible engine failure.
    This practice must stop immediatly. Any dealer fitting any non-genuine parts or accessory on a Ferrari that is under warranty will be held responsible for all consequential repair costs for that car for the remainder of the warranty period and Ferrari will also hold dealer responsible for any other related liabilities, e.g., accidents, personal and property damage, etc.
    Sincerly
    Adam Rowley
    V.P. Technical Services
    FNA
    John J. Maggio
    Director, Parts & Accesories Operations
    FNA
  6. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    I read the above message before but in this case the 355 should be out of warranty anyway - so why would FNA really care? Possibly the dealership doesn't want to perform the task - there could be a valid reason for this.
    Anyway, I am sure you can find an independent shop capable of performing this task. From what I have read here, it seems like a relatively simple task. Good luck.
  7. roro
    roro Formula Junior
    Aug 28, 2006
    843
    Houston, TX
    Ro
    Yes, I got mine installed at Progressive. My good friend Taza owns the place and his folks do top-notch work. Price is great as well!
    www.progressiveautosports.com
    They work on exotics all day long!!!
    PM me if you want to discuss. I can forward you to him. Tell him Ro with the 360 sent you.
  8. buzz69er1980
    buzz69er1980 Rookie
    Jan 1, 2007
    21
    houston
    Paul
    Thanks everybody. I will PM a couple of you for more info..
  9. MurcieMurcie
    MurcieMurcie F1 Rookie
    Jan 31, 2004
    3,100
    I agree with Ro, Taza does great work, did some MB work for me and hooked up Scott with wheels for the Gallardo.
