Footwell Fire Extinguisher | FerrariChat
Discussion in '360/430' started by Kevin Rev'n, Sep 17, 2013.
  1. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    #1 Kevin Rev'n, Sep 17, 2013
    Well I wanted to add some functional red to the cabin of my car so I broke down and bought the very sexy Competition Components Fire Extinguisher setup Competition Components - Competitive Racing Safety Equipment
    I suspected that I received the wrong mount for my car since I couldn't understand how to make it work. When this happens to me because of my remoteness I am faced with eating crazy shipping costs and the time lag in transit or fixing myself. Ten seconds later I had the hack saw out and then I decided to go full monty... then I succumbed to little self inflicted scope creep and started scrounging around the garage.
    I have had this cup holder from a BMW sitting on top of my toolbox for a while with plans to integrate into the cabin so I put all that together with a few hours here and there and wallah. I am moderately happy with the effort. I want to redo the U-channel spacer that holds the cup holder with some thicker extrusion but I didnt have any handy. I will use 1/8 thick material when I re-do which is the same as the main rail. It is a little flimsy as is but would be fine for a small drink until I get around to it.
  2. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Ingenious minds always find a way.
    Alan
  3. LewSF
    LewSF Formula Junior
    May 20, 2013
    579
    San Francisco
    Lewis Blevins
    If I put a fire extinguisher in my Scud.... I don't think any ladies would wanna go for a drive with me.
  4. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    i like it! Well done. :)
    Question: What are the two items in the footwell?
  5. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    Those are desiccant canisters. I use them to combat the humidity when not being driven adn put them in the boot with the cover when driving!
  6. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    #6 Kevin Rev'n, Sep 17, 2013
    I am running the cup holder in reverse of what the stock use is, I dont think it's a problem. I got the idea from one of the 612 guys.
  7. 'Da Wolf
    'Da Wolf Formula Junior
    Jun 25, 2009
    696
    Sadly not California
    OOhhh now someones been thinking - thats ingenious. Well played sir.
  8. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Amazing.
    2 quick somewhat random questions on the extinguisher, since I've been thinking of going that route.
    1. Can you easily reach the "pull" and grab the extinguisher with your right hand while in the factory seat belts?
    2. If you could NOT move your back from the seat (theoretically - like if you were in racing harnesses, could you reach the extinguisher?)
  9. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    #9 Kevin Rev'n, Sep 17, 2013
    1. Haven't tried but that's a good question. I mounted it pretty far forward to create room for the cup holder so I am sure it could be setup to do this by moving it back. Also you could mount the tank part of the clamping system further toward the end of the tank and get the pull that much closer.
    2. I am pretty sure you could customize the mount to get it up high enough to reach the pull just beyond where you would reach to shift into 5th or 6th.
  10. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Thanks, really appreciate the info!
  11. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    Just tell them that things have been known to get pretty hot in here so it's just a precaution Ms. Debutante ! :)
  12. 808Forza
    808Forza Formula Junior
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
    Nice work Kevin! I've been wanting to add one to mine but don't want to hack the carpet :( so when are you doing mine :p
  13. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    You know I will! We just need about $20 bucks worth of parts and an hour or so to fab the custom rail. (and of course the awesome Safecraft extinguisher & bracket). If you want the cup holder I got mine from ebay for about 100 bucks. They come in different finishes IIRC so finding used might take a little effort.
    The hardest thing of the entire process is getting the garage when my wife's car is gone so I have access to my workbench! :-(
    Let's talk!
  14. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    So, is that just a flat piece of 90deg aluminum stock that fits to one bolt on the seat, and then attaches to the safecraft pb2 flat plate mount? If so, does that one bolt hold that thing securely enough?
  15. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,138
    Fort Washington, PA
    John S
    Did you have to drill into the car to mount this?
  16. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    #16 Kevin Rev'n, Sep 18, 2013
    No, toward the front of the 360 seat rail there is an unused hole that is about 5/16ths and that is the attach point. You need to remove the plastic decorative end cap from the rail to access it but it just pops off. Screw shown with washer for reference.
  17. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Am I correct that there is a second hole approx 1-2" back behind as well?
    Is this the kit from competition components?
  18. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    I am an using .75 x .50 x 1/8 Aluminum extrusion (short leg toward tunnel). I am certain that it is secure enough for my application. When tightened with a small shim forward of the attach hole (between seat rail and extrusion) it creates an interference fit with the carpet on the center tunnel and the weight of the extinguisher keeps it tight against the floormat. It might be an issue in a rollover but this concern could be engineered out with some bigger extrusion or bar stock for the accessory rail. I wanted petite and worked with materials I had laying around.
    The thing you are calling the pb2 flat plate mount I had to fab also. It is alum bar stock 2.00 x .250. I cut it about 4-5 inches long to establish the height of extinguisher and that attaches to the supplied mounting block that comes with the extinguisher and the extrusion rail. I could measure any of this for you if you need but your assembly might need to be tweaked here or there based on how far you want the extinguisher from the seat and how thick your floormats are. I made mine long so I could accommodate the cup holder.
    ... and I still have this fantasy that I am going to use the 360 for golf and wanted to be able to slide seat far forward!
  19. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    #19 Kevin Rev'n, Sep 18, 2013
    Yes but.......
    The kit I received from Competition Components was not correct for my car so I had to Macgyver this contraption to use the bottle and hardware that came with it.
    I think the part that CC uses would be the way to go for ultimate strength and he only charges like 75 bucks for it! It is a beautiful part that is wrinkle painted black. Here are some pictures of it when I was trying to figure out how to make it work. I had to flip the pin block over to even get it close to useable but then it was going to require heavy mods to get it mount as clean as I demand against the center tunnel. That's why I suspect I received the wrong part because I couldn't find any complaints about the product anyplace online. The guy "Dan IIRC" is great to speak with on phone.
    First picture is a test fit after I flipped the mounting block (with hole) 180 deg and you can see that I was going to have issues with the angle of the bar and the angle of the seat rail attach point. Instead of shipping it back to him and the cost and lost time I chalked it up to "knowledge" and went to find some materials and a hacksaw.
    Second picture is how it fit when I bolted it to the seat rail with supplied bolt. I messed with the alum mount block but I could see no way to get around this undesirable condition. The rest are me trying to figure out what I had before me.
  20. LouB
    LouB Formula 3
    Apr 15, 2001
    1,811
    FL, OR
    My 430 came with the factory Fire Ext. and has two mounting points under the rug which you can screw into through the rug. Very neat. I believe all 430's had this? Right. wrong?
  21. 808Forza
    Jan 5, 2013
    417
    Honolulu, Hawaii
    Gil
    Thanks for the offer buddy! May take you up on it if I run into difficulty while installing it :)
  22. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    #22 cm2, Sep 20, 2013
    I temporarily mounted one here. I like that it's out of the way, but I'm not satisfied that either in front of the seat or on the right of the tunnel is that easy to reach. I'm even thinking under/in front of the driver's seat might be best. I thought about flipping it around so that the pull was on the seat side... the problem is when its pulled in that configuration, the extinguisher falls to the floor. In this configuration it falls towards the seat and is still accessible. Curious what others have done, since this one will likely move at some point :)
  23. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    #23 Kevin Rev'n, Sep 20, 2013
    I like your mount. I wanted to do this but couldn't find what mount to use so I went with tunnel. I think your fix is right around the corner. Just move the tank bracket down to the base of the extinguisher, then use some 1/4 thick aluminum bar stock to fabricate a simple mount and vary the dimensions until you get the pull handle where you want it.
  24. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    So then the pull would be close, but what happens when you do pull it! Does the extinguisher fall down to the right? Maybe I'm asking too much :)
    Btw I used a Brey Krause universal seat mount. The install was... Interesting. It does not move with the seat the way I did it.
  25. Kevin Rev'n
    Nov 29, 2009
    24,502
    Honolulu
    Kevin
    Great question and I wondered why you wanted to reach it with one hand in the first place because it is heavy and it takes two hands to control the thing when you pull the pin from any orientation.
    Actually with the mount at the butt of the canister it might create a condition of being pinched in place with so much of the mass tilting forward. It "might" stay right there when you pull the pin!
