For the gas vs charcoal debate... | FerrariChat
Discussion in 'Drink, Smoke, and Fine Dining' started by David_S, Jan 20, 2014.
  1. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    This weekend, I decided to do some yummy burgers on the grill. Last year, I settled on a Char Broil Tru-Infrared propane grill.
    I've been pretty pleased with that grill during normal weather, but... at sub-freezing temperatures - I had to take the propane tank into the house to warm up up enough to get ANY pressure (soaked in 100+ degree water for over an hour) - and afterwards, the grill would only register around 700 F (which is measured below the cooking surface) - so it took 20 minutes plus to fully cook 3 burgers.
    Just saying that a good charcoal system could certainly reach and maintain sufficient heat much more quickly...
    Miss having a dependable cooking surface that could be guaranteed to be 500 to 800 degrees...
  2. Vinny Bourne
    Vinny Bourne Formula Junior
    Nov 25, 2011
    910
    nothing compares to Kingsford, the whole process is fun, from lighting them, to watching them glow in the dark when done (and marshmallows). The fire sears the outside of a hamburger perfectly and adds a great taste.
  3. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    16,898
    Wellington, FL
    Duane
    If you think processed Kingsford briquettes are good you should try natural lump charcoal. I buy the Fresh Market/Whole Foods brand. It's unprocessed, all hardwood and simply better than any briquette.
  4. Norm512TR
    Norm512TR Formula Junior
    Nov 10, 2001
    895
    Colorado Springs, Colorado
    Norm
    I'd blame the BBQ before I'd blame the fuel. I never have a hard time getting my propane BBQ up to the right temp, this past week it was about 6 degrees and I did three rib eyes that were about 1 1/4 inches thick- two minutes of sear on each side and about five minutes of indirect heat to finish.
  5. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,836
    Richmond
    Pete
    I made the switch to charcoal about 7 years ago and there's no going back. I have to say after going through three or four grills in that time trying to find a versatile one with good temperature control to just buy either a big green egg style grill or the traditional Webber kettle grill. They have the best temperature control and let you do anything from smoking at low temp to searing steak or cooking pizzas at high temps. I bought the char griller akorn and in 6 months have only used two bags of lump charcoal, and I cook on it once or twice a week minimum. It's so air tight that you just close the dampers and reuse the charcoal for the next meal. The barrel style grills I had before would use about 5x as much coal.
    Also, a $15 charcoal chimney and you never have to mess with lighter fluid again, plus it gets the coal ready in less than half the time.
  6. David_S
    11,260
    Mountains of WNC...
    David S.
    Naaa, I think it was safe to blame the fuel: my little propane pressure gauge wouldn't even come out of the red (empty) range until I bathed the tank in hot water for a while - even though I could feel by weight & sloshing that it was at least 1/3 full.
  7. Skidkid
    Skidkid F1 Veteran
    9,496
    Campbell, CA
    John Zornes
    They are for completely different things. Briquettes generate a lower heat and sustain it for a much longer time. They are great for grill roasting, slow cooking, etc.
    Hardwood charcoal produces MUCH higher heats but doesn't last as long. It is great for hot and fast like searing steaks, fish, etc.
    I have both and use both. I also have a gas grill for rainy days or late evenings after work when I want to grill but don't want to wait on the charcoal.
  8. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    16,898
    Wellington, FL
    Duane
    I can cook all day long, maybe 24 hours+ off one load of lump in my BGE. In other words I can get it down to around 195 and maintain that temp for hours.
  9. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    Great grill. I have an infrared CharBroil, jetted for natural gas and hooked up to my household supply. No fussing around with propane.
    Matt
  10. Jdubbya
    Jdubbya The $10 Trillion Man
    42,485
    PNW
    I agree. Love my little Weber grill. Quick and easy to light using a chimney and some paper. Easy to control the heat using the top and bottom vents.
  11. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,836
    Richmond
    Pete
    Same here, the lump only burns hot if you have no air control.
  12. vincent355
    vincent355 F1 Veteran
    6,498
    Wine Country
    Vincent
    Wasn't aware of any debate...all my gasser is good for is storage. I haven't used it in years.
    Lump and a weed burner, I can be cooking before the grill on the gas grill gets hot enough (which it never does)
  13. Jdubbya
    42,485
    PNW
    You know I keep forgetting about my weed burner. I may have to try that next time instead of the chimney. You just pile it in the bottom and torch away?
  14. boxerman
    boxerman F1 World Champ
    19,547
    FL
    Sean
    No debate, charcoal, the rest/gas is just conveniance.
  15. vincent355
    6,498
    Wine Country
    Vincent
    Yep, fire it up, go inside get meat ready to grill, spread coals and grill. Sometimes I have to let it mellow a bit first. Nice thing is that I think the chimney gets the coals too hot, with the weed burner you have more control.
  16. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    Briquettes are convenient. But you really don't want to know what they're made of.
  17. Derek at FoD
    Derek at FoD Formula 3
    1,924
    Denver
    Derek Fennig
    I wish I had a choice...I live in a mid-rise apartment building in downtown Denver and unless you've got a gas line running to your balcony you can't use anything larger than those little camping cannisters. :(
    I still make do and grill about once a week. :)
