For those single engine airplanes with parachutes... | FerrariChat
Discussion in 'Aviation Chat' started by GTHill, Apr 9, 2017.
  1. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    I'm curious... when should it be deployed?
    If you lose your engine at 5000 ft. Do you deploy? Or do like a regular pilot and find a suitable place to land? When is the go / no go for deployment? I'm sure it varies per airframe... just curious about the use of these.
    Thanks!
    GT
  2. alexm
    alexm F1 Veteran
    Sep 6, 2004
    5,223
    Coast up from Sydney
    Alex
    I'd say when you have no great option for gliding to a probable landing.
    Had one deploy here last year over the rugged mountains.. it's pretty much a barrier range dividing Sydney from the rest of the country and unavoidable without a significant diversion.
    if something goes wrong over here there's very very little to choose from.. its all trees and high cliffs.. a few cleared valleys if you're near them but mostly not much else of a landing option.. they popped the chute to end up in someones front yard.. better than ploughing into things at much higher speed..
  3. alexm
    alexm F1 Veteran
    Sep 6, 2004
    5,223
    Alex
    You can get a view of the rugged areas getting in and out of Sydney.. a chute would be a godsend when things go wrong over here.
    It proved quite the barrier for some time for white man to find a way through..
    https://goo.gl/maps/LEfdngoHNns
  4. loflyer47
    loflyer47 Formula Junior
    Sep 28, 2004
    362
    Phila. area, Pa.
    Ben
  5. toggie
    toggie F1 World Champ
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    #5 toggie, Apr 12, 2017
    The "after" pictures of a Cirrus parachute emergency landing are interesting to look at.
    It is impressive how safely the plane lands in rough terrain areas.
    My understanding is that the airframe is a total loss when the CAPS system is deployed.
    Here is an example picture found on the internet.
  6. toggie
    Nov 30, 2003
    19,036
    Virginia
    Toggie (Ron)
    Here is a facebook video of an actual Cirrus CAPS emergency landing.
    Video was captured by a security camera.
    The plane descends quickly and the landing is probably a bit rougher than you might expect.
    But, both passengers were able to walk away from it.
    https://www.facebook.com/NBCNewYork/videos/10153963371469099/
  7. Jason Crandall
    Jason Crandall F1 Veteran
    Mar 25, 2004
    6,375
    ATL/CHS/MIA
    Jason
    Any good pilot knows the answer to this questions is "it depends".
    It depends what's going on. Lot's of factors to consider. Training is done so one can "consider the factors" while under pressure.
  8. jcurry
    24,153
    In the past
    Jim
    First rule if you run into this type of situation is to do whatever it takes to get yourself safely on the ground. Consider the airplane totaled from the get go, i.e. don't try to save it above yourself and your passengers.
  9. ersatzS2
    ersatzS2 Formula Junior
    Jan 24, 2009
    862
    Norfolk VA
    The Diamond community is fond of repeating the assertion that the descent rate of a DA40 in full stick-back nose-up stall is the same as a Cirrus with the chute deployed. Not sure that is relevant in a thunderstorm but interesting if true.
    what impressed me about that video was how well the gear sprang back after that hard hit! Obviously I've been overly squeamish about dropping 3 feet to the runway when I flare too high!
  10. joker57676
    joker57676 Two Time F1 World Champ
    Apr 12, 2005
    23,767
    Sin City
    Deplorie McDeplorableface
    Actually, the rate of descent in a Diamond mushing to the ground is SLOWER than a Cirrus with the chute pulled...and I don't how effective a chute would be if pulled in a thunderstorm either.
    Mark
  11. ECHO CHARLIE
    ECHO CHARLIE Karting
    Jul 8, 2009
    110
    Has anyone survived a crash in a Diamond ,"mushing " to the ground ?
    Edward
  12. joker57676
    Apr 12, 2005
    23,767
    Sin City
  13. norcal2
    norcal2 F1 Veteran
    Looks like 300ft doesn't work....
    SONOMA, Calif. (KGO) -- When investigators from the FAA and NTSB arrived at the crash site Friday morning they found a crumpled Cirrus SR22T plane and descriptions from witnesses of an engine failure shortly after take off from the Sonoma Skypark.
    "When the engine stopped, it became a glider and looked really good," said airport manager Ron Price. "I was hoping they could land in that field."
    Instead, for reasons unknown, pilot Bill Goldman pulled the handle on the parachute designed to save planes in distress. It worked on June 30 near Davis, when a pilot and passenger walked away after an engine failure.
    But it did not work in Sonoma for a plane at maybe 300 feet, according to witnesses.
    "The parachute needs about a thousand feet to deploy, and that is only if you're lucky," said San Rafael aviation attorney Lou Franecke. He made a case against Cirrus after a similar crash.
    He cannot discuss the settlement terms but insists the plane has a flaw. "The parachute is used to deploy when you have a problem," Franecke told ABC7 News. "And the problem with the Cirrus is its aerodynamic characteristics are awful in stall."
    The Cirrus Aircraft Company makes a selling point of the plane's built-in parachute.
    Today it told us: The Cirrus Aircraft whole-plane parachute system has been deployed 72 times over the last 18 years, resulting in 148 saved lives who were returned to their families.
    But as Coast Guard video shows, deployment does not happen instantly. It takes a few seconds for the straps to deploy, the chute to fill, and for the plane to level.
    Friday, witnesses say the plane landed almost nose first. Would the chute have made a difference at low altitude? The company says it can work at 400 feet.
    "If you are straight and level," said Franecke. "But if you are straight and level, why would you deploy the parachute?
    The answers may lie somewhere in the wreckage.
  14. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ
    14,767
    Juan
    So the chute put him on the nose but I think three survived? Check out the pictures in Kathryn's report. Is it possible the chute saved their lives? I don't know the answer to this, but although it killed one, maybe the others lived due to the plane being slowed prior to impact? Sounds like they could have glided in as this one just did?
    Kathryn's Report: Cirrus SR22, N754AP, Alpha Papa LLC: Incident occurred July 15, 2017 in West Point, Davis County, Utah
    Kathryn's Report: Cirrus SR22T, N821SG, DDLV LLC: Fatal accident occurred July 13, 2017 near Sonoma Skypark (0Q9), Sonoma County, California
  15. Juan-Manuel Fantango
    14,767
    Juan
    #15 Juan-Manuel Fantango, Jul 17, 2017
  16. Island Time
    Island Time F1 World Champ
    12,053
    E. TN
    David
    For me it'd take a lot. Probably about the same situations that would make me jump if there was a chute on my back. (airframe failure, engine failure at night over mountains...).
    It'd be a "pick your poison thing"
    I know they turn a lot of people on
  17. Island Time
    12,053
    E. TN
    David
    Uncontrolled disorientation in IMC might be a good time...
  18. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    That sounds terrible!
  19. Island Time
    12,053
    E. TN
    David
    It's what happened to John Kennedy Jr. at Martha's Vinyard 20 years ago. Probably kills more pilots than just about any other thing. Pilots flying into or getting caught in weather that's a problem for them. It can happen. auto-pilot failure .... lack of training...etc....stuff adds up
    my thinking is that's where these parachutes would save the most lives...but I really don't know that much about them.
