Foredit Water Pump | FerrariChat
Foredit Water Pump
Discussion in 'Vintage (thru 365 GTC4)' started by swift53, Jun 15, 2017.
  1. swift53
    swift53 F1 Veteran
    6,723
    E.S.
    Alberto
    #1 swift53, Jun 15, 2017
  2. TTR
    TTR F1 Veteran
    5,184
    Riverside, CA
    Timo
    PM sent.
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    That is the real McCoy. Very rare and hard to find, especially if it works. Used on some 246gt/gts and Daytona, probably used on other models as well.
  4. racerboy9
    racerboy9 F1 Rookie
    2,514
    Looks like someone has repaired that one as the bottom section should be riveted together. I have several NOS units but the problem is the pump mechanism which is a rubber tube with rollers that push the windshield washer fluid. Over time the rollers have set in one position and squished the rubber tube flat. The rubber tube looks like surgical tubing to me and would be easy to replace if you drill out the rivets and replace it.
  5. swift53
    swift53 F1 Veteran
    6,723
    E.S.
    Alberto
    Timo, here is your solution...
    Regards, Alberto
  6. swift53
    swift53 F1 Veteran
    6,723
    E.S.
    Alberto
    What do the rivets look like? Could you post a pic?
    Thank you.
    Regards, Alberto
  7. racerboy9
    racerboy9 F1 Rookie
    2,514
  8. swift53
    swift53 F1 Veteran
    6,723
    E.S.
    Alberto
    The one I have, has different length spouts, and i did replace the plastic tubing
    with chain saw fuel line, surprised at the power.
    It is peculiar design, yet very clever. After a Da Vinci invention :)
    Regards, Alberto
  9. flaviaman
    flaviaman Formula Junior
    Jul 26, 2005
    310
    Vernonia, OR
    Gregg
    Fiat used these in early 70's on 124, 850, Dino etc. I have bought several NOS units off eBay.it, regrettably the plastic tube inside was rock hard. Replacing the tube is easier said than done!
