Forward Center Console Switch Connectors...Is This Right? | FerrariChat
Discussion in '348/355' started by The Outcast, May 29, 2018.
  1. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    I took my console apart. Not sure if I've got the connectors in correct order. In the photo, the "comfort" ride switch is on the right. I'm sure about the three (white, red, black) on the left hand side of the photo, but I'm not sure if the black and white on the right side of the photo are correct. Anybody know?
  2. Qavion
    Qavion F1 World Champ
    14,428
    Ian Riddell
    Depends on left or right hand drive, but, in the past I've had to go by wire colours:
    Suspension: Black/violet, white/red, red/green, yellow/red
    Door unlock: Yellow/red, violet/white, black (with wire loop to), black
    Door lock: Yellow/red, brown/green, black (with wire loop to), black
    Rear fog: Black, orange, orange, yellow/red
    Heated window/mirrors: Black, Green, Blue/red, Yellow/Red
    On my spider, with only heated mirrors, I have these colours:
    Black, green, blue/white, yellow/red
    Yellow/Red wires are for switch backlighting, so they all have that colour. Go by the other colours.
    The colour after the "/" is the narrrower stripe colour.
    Hope this helps
    Cheers
    Ian
    (EDIT: Do USA cars have rear foglights? If not, what is the switch (and its wire colours). I'll add this detail to one of my custom wiring diagrams.
  3. sevminasyan
    sevminasyan Formula 3
    Jun 24, 2008
    1,156
    Glendale, CA
    Steve
    Just toggle the switches with the key on and u can answer your own question
  4. Qavion
    14,428
    Ian Riddell
    The door switches are momentary. They probably won't switch on fog lights, heaters or suspension if you mix those up.
    Dave rocks likes this.
  5. The Outcast
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    Thank you!
  6. The Outcast
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    I'll let you try that...
