Found a surprise in my sub woofer box | FerrariChat
Discussion in '360/430' started by SCKOMS, Aug 6, 2014.
  1. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    I decided to upgrade the speakers in my subwoofer box with some Pioneer speakersper the recommendations in another forum. When I removed the existing speakers I was pleasantly surprised to find a Focal speaker (not a sub; model 5KP) in the lower cut out..of course the passive curtain was still there. I swapped the passive with one of the Pioneers and the sound is much better but now I have some questions:
    Should I replace both speakers with the Pioneers so that they are matched?
    Since the sub woofer was upgraded there is a chance (I hope) that the door speakers and tweeters have been replaced...is there a way to tell without removing the door panels?
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
  2. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,527
    Honolulu
    Kevin
    You can check the tweeters in minutes with no tools. Just pull the triangle trim piece from the top inward and then when it clears the rubber door gasket lift it up! NO screws. Take a picture and post it up. Someone will know.
  3. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    Thanks.. will try that tomorrow.
  4. Malachiman
    Malachiman Karting
    Apr 4, 2014
    69
    Japan / USA
    Jeff
    Good info..I need to do this.
