Found cracked hose to bypass valve | FerrariChat
Discussion in '348/355' started by LotusS4, Aug 20, 2009.
  1. LotusS4
    LotusS4 Karting
    76
    Long Island, NY
    Just wondering, I was working on my 99 spider tonight and was installing a Tubi. After taking everything apart, I got to the vacumn hose to the bypass valve. Before I went to undo the clamps I just ran my finger down it and found it cracked and split by the lower clamp.
    So my question is, is it possible the valve was not actually opening and if so, would that have normally thrown a check engine light? I never had one but was just curious. I also found a cracked lower clamp on the muffler that needs to be replaced but it was still tight.
    And if the valve was not working would it have impacted performance that much?
    99 Fiorano TDF
  2. Rifledriver
    37,288
    Your profile has been left blank so it is a little hard to answer you questions. The answers vary depending on where you are and your car.
  3. LotusS4
    LotusS4 Karting
    76
    Long Island, NY
    ok, its a 1999 F355 Spider F1 and I am in NY. I did some deeper searching after my first post and someone had posted that if the vacumn hose was actually disconnected it should NOT set off the check engine light. Just wanted to see if anyone else can confirm that??
    Since I am a fairly new 355 owner, I am not not sure I heard a difference after any set RPM level??? I did always feel like it did not make alot of power up top but that may just be me going crazy.
    Sure am looking forward to this weekend and the show in Glen Cove NY. Although really hope FerrariLI has the exhaust clamp instock otherwise I will be trying to figure something out.
    99 Fiorano Spider TDF
  4. Rifledriver
    37,288
    In a US car its failure to function should set a check engine light. The temp sensor in the pipe down stream of it is intended for that purpose only. A crack in that hose is quite common and it requires a special hose to deal with the heat.
  5. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    Ricambi has the exhaust clamps.
    If you didn't hear a difference, then it probably wasn't working. It's a pretty significant difference.
    Mr Crall, thanks for the input. I put a Capristo bypass valve on last year requiring longer hose, so I just got whatever they had at Autozone. I will inspect for heat damage and insulate as needed. Best regards.
  6. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,976
    MD and NE
    Robbie
    My 98 355 doesn't have a bypass valve anymore....:D
  7. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    :D
