Found the A/C leak finally!! | FerrariChat
Discussion in 'Mondial' started by efinn, Jun 27, 2011.
  1. efinn
    efinn Rookie
    May 25, 2010
    42
    Stamping Ground, KY
    Eric
    After Searching and dying and refilling last year, while I was Charging the A/C for a drive to the Casino this weekend, I found the leak. In what should have been an easy place to find it. The Pressure Switch on the Receiver/Dryer was pouring out the charge. Have a new one on order from Rutlands, hope this is the only one.
  2. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    I have a leak on my compressor. I really would like to change it one day but it does not get too hot here in Montreal. Usually have the top down.
    good luck with that.
    Lino
  3. PAP 348
    Dec 10, 2005
    100,205
    Mount Isa, Australia
    Pap
    You're lucky mate, easy fix. :D:D
    I had a leaking shroder valve on my low side when I first bought my 348 in 2005. Changed it out, fixed the leak. :):)
    3 months later I blew the high pressure hose on the a/c compressor. Changed that out and it's been GREAT ever since. :D:D
  4. efinn
    efinn Rookie
    May 25, 2010
    42
    Stamping Ground, KY
    Eric
    Well, dryer installed, evac and charge complete, 1st road test a sucess. Now time will tell if the charge stays. Purchased the rec/dryer from TRutlands...quick service, correct part.
  5. PAP 348
    Dec 10, 2005
    100,205
    Pap
    Cool man, hopefully it's all good. :)
