Found the reason for my overheating problem | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Al Campbell, May 14, 2014.
  1. Al Campbell
    Al Campbell Formula Junior
    Nov 22, 2013
    581
    Australia
    #1 Al Campbell, May 14, 2014
    After doing all the usual things like checking the thermostat, radiator cap & rebuilding the radiator I have finally found the cause of my overheating issues. There is no nut on the waterpump impeller? There is no sign of the nut, lock tab or washer so I don't know if they have been pushed up into the engine water gallery or if they were just not installed in a previous service. At least the shaft looks OK so it will not be an engine out job but the front housing & impeller do not look cheap.
  2. bjwhite
    bjwhite F1 Rookie
    4,806
    Seattle, WA
    Brian White
    Holy crap, that's nuts!
  3. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,378
    Central NJ
    On Ferraris that nut is an option.
  4. willrace
    willrace Three Time F1 World Champ
    34,970
    North Tay-has
    Kurt
    OUCH!! . . . . . These days, you may be right, though :D
  5. Ak Jim
    Ak Jim F1 Veteran
    9,625
    North Pole AK
    Sir, did you want the standard service or the deluxe service?
  6. Al Campbell
    Nov 22, 2013
    581
    Australia
    The parts are on order. I was right it wont be cheap! The front cover, impeller, bush, nut, locking tab, washer & set of seals came to about $1100 AUD. Now for the long wait for them to arrive.
  7. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    29,801
    North Qld
    simon klein
    STREWTH !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  8. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,378
    Central NJ
    Buy a parts car from the States, it will be cheaper in the end...
  9. BigTex
    79,380
    Houston, Texas
    Bubba
    I would have reused the impeller....
    I recently had my water pump done here (they did need parts support on the bearings and seals from Ferrari) but they put a shiny one in my hand for about $465USD.
    Good luck on your (finally) cool running car!
    I am waiting on some radiator fans now....
    :D :D :D
  10. Al Campbell
    Nov 22, 2013
    581
    Australia
    Eurospares have advised me that they can't get the water pump cover part # 104328.
    Does anyone have any leads on a new or good secondhand one?
    Cheers Al
  11. Al Campbell
    Nov 22, 2013
    581
    Australia
    #11 Al Campbell, Jun 2, 2014
    I'm happy to say that my overheating issue has been sorted.
    A new impeller, bush, seals, lock tab & nut were fitted. I ended up taking the water pump front cover off the other 400I that I'm slowly restoring until I can get a replacement from Maranello Parts who are getting these remade.
  12. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Can the old one just be re-surfaced ? Brass (impeller) on aluminum (cover) should not have worn away too much material --- just a lot of galling. The gap tolerance between impeller fins and cover surface should not be too critical...... I might be inclined to take comparative measurements against the good one, and see if you can make her fly :). heck you may not even need to bother with resurfacing ---- just clean up any burrs and sharp edges so they don't shed pieces later into the system ????
