Found throttle body shaft seal replacements CHEAP! | FerrariChat
Discussion in '348/355' started by FSM348, Sep 18, 2018.
  1. FSM348
    FSM348 Formula Junior
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    I'm in the process of restoring my 348 and after powdercoating the throttle bodies I realized replacement throttle shaft seals on the TB were necessary. After a crazy amount of searching a little shop which happened to be local to me just so happened to have perfect sized replacements. 8mm x 12mm x 3mm rubber seals.
    These seals fit both the throttle bodies and the intake manifold butterfly shaft seals.
    Metric Seals
    Westfield, Indiana
    metricsealsinc.com
    part number S 8 x 12 x 3 WOA
    https://www.metricsealsinc.com/single-lip-springless/022044-s-8-x-12-x-3-wao
    SPECS:
    Single Lip Spring Less Oil Seal
    BAOF, VC, WAO, INA, VG
    Specs:
    Radial shaft seal with rubber covered O.D. And sealing lip without spring.
    Material:
    NBR (Natural Rubber), Plain Steel insert.
    Max Temperature: -40°C/-40°F – 100°C/ 212°F
    Max Surface Speed: 6 m/s
    8mm ID x 12mm OD x 3mm
    Application:
    Grease
    Simple sealing element for ancillary use; to seal against grease; as an additional seal against light to medium dust and dirt.
  2. fatbillybob
    Aug 10, 2002
    28,646
    socal
    Good find...put it in the parts interchange in master sticky.
  3. FSM348
    Feb 13, 2017
    469
    Midwest
    Dan Smith
    Done
