Buy
Four post lift
Discussion in '360/430' started by Dino6304, May 16, 2022.
  1. Dino6304
    Dino6304 Formula Junior
    259
    CT
    Laurence
    Will the front valance of the 360 or 430 clear the the lift when driving onto the typical four post lift.
  3. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    269
    I have a Lift Superstore 8k and yes it does just fine. Using the aluminum ramps but I believe they are the same as the steel ones usually included as far as length.
  4. Dino6304
    259
    CT
    Laurence
    Thanks very much
    Debating a standard four post lift vs the Autostacker
  5. Extreme1
    Extreme1 Formula Junior
    Jun 27, 2017
    850
    Santa Clarita, CA
  6. CoreyNJ
    CoreyNJ Formula 3
    1,057
    New Jersey Shore
    I'd be curious if you can open the doors of an F430/360 when it's on the lower level of the auto-stacker without leaving the bottom car hanging out 1/3 or if that is the only way it works? The only video I see on their website with the door opening has the bottom car backing in, If that is the case, then it's a good reason not to get an Autostacker.
  8. plastique999
    plastique999 F1 Veteran
    Silver Subscribed Owner
    Nov 9, 2008
    7,425
    SoCal
    Edward
    I use longer Race Ramps
  9. tstuli
    Jun 12, 2018
    269
    I don’t see any distinct advantage to the autostacker other than perhaps looks? You end up with reduced flexibility.
  10. ttforcefed
    ttforcefed F1 World Champ
    17,166
    whatever goes on the lift, never comes down, fwiw.
  11. flash32
    flash32 F1 Rookie
    Aug 22, 2008
    3,799
    Central NJ
    Dominick
    +1. And so light
    plastique999 likes this.
  13. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    264
    Covington GA
    Tam V.
    Stock height should clear no problem
  14. colorfull
    colorfull Formula Junior
    745
    Franklin Park, New Jersey
    John Napoli
    Doesn't a 4 post allow you to work on the underside of the car? Or not quite enough clearance?
    The Autostacker looks tre cool, but seems much more limited in function since you can't get to the underside of the car.
    Even just for parking, seems to have drawbacks as Corey points out
  15. plastique999
    Nov 9, 2008
    7,425
    SoCal
    Edward
    Totally true… I don’t use the metal ramps that came with the Bendpak because they are so damn heavy!
  16. plastique999
    Nov 9, 2008
    7,425
    SoCal
    Edward
    Aw come on Ricky!
    At least once a month I’ll let it down.
    I only wish I had it hooked up to 220V.
    Now if I only had a rotating 8 stacker….
