Fribillating 328 Gas Gauge | FerrariChat
Discussion in 'Technical Q&A' started by billg, Jan 4, 2012.
  1. billg
    billg Formula Junior
    Jun 7, 2006
    307
    New Orleans
    Bill Grady
    Took it out this morning, fuel gauge dead, all the way left, no 'low fuel' light on, and I know the tank is near full. After 10 miles or so, I notice the gauge is twitching. Closer I get to home, more twitching until in front of the house it swings to half full, after I have switched the ignition off and then on again. I pull it into the driveway and the gauge moves almost all the way right, registering correctly.
    What's going on here.
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Sounds like a bad connection - start with having a look at/cleaning the spade connections on the top of the LHS tank.
  3. billg
    Jun 7, 2006
    307
    New Orleans
    Bill Grady
    Thanks. What's the LHS tank.
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Left hand side fuel tank. If you look at it from the engine bay you will see a round thing on the top of it with 3 wires connected to it - that is the fuel gauge sender.
  5. billg
    Jun 7, 2006
    307
    New Orleans
    Bill Grady
    Thanks so much. I'll post on finding.
  6. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    Also inspect the connection to ground.
  7. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Agree, probably a bad ground. !st try pounding on the dash in different location to see if the gauge changes.
    I know it sounds rather archaic in today's, world but it can tell you if you have a loose connection in the cockpit!
