Fried Alternator Cable | FerrariChat
Discussion in '360/430' started by 400iGuy, Dec 13, 2015.
  1. 400iGuy
    400iGuy Formula 3
    1,080
    Central Florida
    Al
    #1 400iGuy, Dec 13, 2015
    Anyone had this problem? It started with the battery light staying on. So I figured I needed an alternator rebuild. But nooooooo, not so simple.
    The alternator cable (PN 213155 Complete Connection Cables for Motor Utilities) is fried completely through making no connection. This is on a 2004 360 F1 Spider with ~20K miles.
    It requires the replacement of the complete cable which is connected to a number of things (A/C compressor, starter, electrical connections in the interior behind the seats). After it's replaced then the alternator will have to be checked out and possibly rebuilt.
    Al
    '04 360 F1 Spider Titanium/Bordeau
  2. jtucker
    jtucker Rookie
    May 16, 2011
    28
    I had the same issue two years ago with my 2004 360 6-speed. An expensive repair but the updated cable is evidently more robust. Rebuilt the alternator as part of the repair. Ferrari dealer told me it's not uncommon on 360s, particularly ones in warmer climates.
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    It's a single cable from the starter to the alternator to the + post behind the drivers seat. The other lines are wrapped into the harness with the single large gauge cable from the alternator. I'd say checkout the wiring diagram but Ferraridatabase is gone.
    Not uncommon to have the end of the alternator cable fray and oxidize.
  4. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    1+
    Happened to me and I solved it with a direct cable to the terminal behind the seats.
  5. mr_bock
    mr_bock Formula 3
    Oct 27, 2006
    1,373
    FL full time
    From the picture, it looks like the connection to the alternator has corrosion. That may act as added resistance to the cable and create heat... Just my thought on this. I just had my alternator off and rebuilt as I had to drop the oil pan and A/C compressor. My cable looked fine.
    Good Luck!!!!
  6. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,451
    On the Limit
    Dino
    This is interesting.... I have an intermittent battery light, as well as a hot start problem. I wonder if this cable could be failing.
  7. Monteman
    Monteman Formula 3
    2,345
    Santa Barbara, CA
    Monte
    That is exactly what happened to mine. The corrosion created enough resistance that the cable started to catch on fire. Fortunately, we caught it before it became a bigger issue. Definitely something to keep an eye on if you have the belly pan off.
  8. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,515
    Honolulu
    Kevin
    #8 Kevin Rev'n, Dec 14, 2015
    You can have a new section spliced onto your cable for minimal $$$. I did this to mine at the F-Dealer for ~300 bucks, he used a heavy duty butt splice and added a new cable end. I think it was 3K to replace the cable with new Ferrari part and 1200 of that was labor. The stock cable is a spendy item because it is not a simple loom. I think the part is 179833 here is a picture of it First Pic. 2nd pic is how mine looked on my car with only 9K on odometer and stock electronics. This was in 2014. Third pic is how far the under the sheathing the damage had gone. Last pic is the repaired cable getting for re-install. Note the extra layer of insulation added to end of cable to hopefully give it a long life.
  9. Rifledriver
    37,106
    Actually it really starts with either a poor connection or a perpetually compromised battery.
    Cars with a battery and connections that are being looked after will never have that problem.
    KC360 FL likes this.
  10. 400iGuy
    400iGuy Formula 3
    1,080
    Central Florida
    Al
    Thanks to all who provided input. It makes me feel a little better to know I'm not the only one who's had this problem!
    Kevin, Thanks for the photos. I'm going the route of replacing the cable, I'm just more comfortable with that solution. It's interesting in your second photo how rusted/corroded the nut/stud are on the alternator.
    Rifledriver, I've had the 360 for 3 years and 6,000 miles, it had a new battery when I bought it and it's always been charged as far as I know. During my ownership it's never been on a charger but it's driven regularly (easy to do with Florida weather). Could this have been something that started because of battery issues prior to my ownership?
    Al
  11. Rifledriver
    37,106
    Has the alternator connection ever been checked? Has the battery ever been load tested?
    Both should be done at annual services.
    That may be a common condition but it is not a normal condition. I service plenty of high mile 360's that have never had the problem. It is 100% avoidable.
  12. Kevin Rev'n
    Nov 29, 2009
    24,515
    Honolulu
    Kevin
    #12 Kevin Rev'n, Dec 18, 2015
  13. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Please tell us the result ! :D
  14. Melvok
    Jul 25, 2008
    14,268
    Mel
    DRAKA is a NL firm but any cable firm can replace this imo !
  15. vrsurgeon
    16,543
    Charleston, SC
    Curt
    I'v ehad mine 5 years+ and put 10,000 miles on her. No problem with the alternator. Am Replacing my batteries every 3-4 years preventatively. If she starts to crank slower.. replace. I'd put my money on Prior owners running with a near dead battery. It hasn't just happened in the last 3 years but has been building over time IMHO.
  16. plahaye
    plahaye Rookie
    Nov 2, 2003
    49
    S La. swamp
    Phil LaHaye
    This type failure is not just a Ferrari thing. Had the same problem on my Motor Home inverter cable at the 300 Amp fuse block. Simple fix, cut away the heat damaged cable back to good cable and solder on a new connector if your cable is long enough. Or, as has been suggested, butt splice in a new section of cable with a new connector. No need to change the entire harness and it is a quick, inexpensive, and appropriate fix. A new harness will have the same crimped connectors and may fail again. Soldered electrical connections are always better than crimped connectors by the way.
  17. Rifledriver
    37,106
    Except for the fact that the entire electronics industry does not agree.
  18. Rifledriver
    37,106
    Never seen on cars properly serviced.
  19. Melvok
    Jul 25, 2008
    14,268
    Mel
    Here you have a good point Brian :D
  20. plahaye
    plahaye Rookie
    Nov 2, 2003
    49
    S La. swamp
    Phil LaHaye
    Learn something every day. Looks like you guys were right about the auto industry using just crimped connections. Lot of discussion about both crimped and soldered connections and when crimped correctly, crimps are superior to soldering. The anti-crimping opinions seem to come from crimping without the proper tools and with commonly available cheap connectors. Soldering tends to encourage breakage at the solder margin as that portion of the wire becomes stiff and may break in a high vibration environment and if improper flux is used, that encourages corrosion of the connection.
    Now I have to order an expensive crimping tool! Ignorance was bliss! Thanks for correcting me guys.
  21. Rifledriver
    37,106
    A good solder is better than a bad crimp so do what you are good at.
    The point is in a controlled environment crimps are better.
  22. Kevin Rev'n
    Nov 29, 2009
    24,515
    Honolulu
    Kevin
    I try to mention checking this cable whenever someone starts asking about a garage queen purchase because this has been my experience with mine. My car was serviced correctly AFAIK from Newport Beach Ferrari and Eugenio over the 11 years before I picked it up. The car only had 5700 miles on it though!
  23. Rifledriver
    37,106
    Most of those when I check them are loose.
    That means more resistance, that means more heat, that means more resistance....china syndrome.
    Cars need to be taken care of. It is really that simple. Those cables die because of poor maintenance. It took a long time to get that way. That means there were a lot of missed chances to stop it from happening.
  24. 400iGuy
    400iGuy Formula 3
    1,080
    Central Florida
    Al
    #24 400iGuy, Dec 23, 2015
    Here is what the offending cable looks like. From my untrained eye it looks like only 3/8 of an inch of the cable was in the end when it was soldered together.
    Rifledriver said it won't happen in a well maintained car and I plan on doing that so I don't expect to see this failure again!
    Al
  25. Jaymac
    Jaymac Formula Junior
    975
    New Hampshire
    Jeremy McCurdy
    I just found this thread after this happened to a friend of mine recently. Led to the alternator losing power which led to the car dying in the middle of an intersection after the Cavallino Classic this year. Had to be pushed to the side of the road. After getting diagnosed at Ferrari of Palm Beach with an exorbitant quote, he found an Indy in the area who offers the service of splicing in new cable and connector where the original was corroded and burned for a fraction of the cost. After he told me of his experience, and that the Indy mentioned it being a somewhat common occurrence, I found this thread, and pulled my pan to check mine right away. Thankfully, my connection and hardware to the alternator are shiny and clean, with no corrosion on the cable itself. From Brian’s advice, I checked the nut for proper tension, and was able to get less than an 1/8 turn out of it, but I was happy to have it snugged up. Happy days! This is now definitely on my checklist of items to inspect every time I’m in there from now on.
    Thanks!
    collegeboy and Qavion like this.
