Friend persuaded me to wash engine bay... now no alternator | FerrariChat
Discussion in '456/550/575' started by belfry, Jun 29, 2025.
  1. belfry
    belfry Formula Junior
    May 14, 2015
    486
    Robert Batt
    Last weekend my friend was over and he said that I should wash the engine bay as it was very dusty.
    I was apprehensive so i didn't go crazy and just used a hose on low and some detergent. Then I put the car away in the garage. (1995 456GT)
    I just went to start the car and I noticed that the battery light stayed illuminated. 11.72 volts at the battery with the engine running. The belt is tight and the alternator is turning.
    I have a spare 456 alternator on the shelf but I though I'd check on here to see if there was anything else to check before I replace the alternator?
    The existing alternator is about 5 years old and probably has 12,000 miles on it.
    Any thoughts greatfully received.
  2. Rifledriver
    37,090
    My first thought is your friend is an idiot. I have seen so much costly damage done washing engines I never do it unless its out of the car and I have spent a couple hours protecting the stuff that should not get wet. Also detergents are almost all corrosive at some level. Electrical equipment really do not respond well to that.
    Many engine cleaners on the market. None have a detergent like chemical make up.
    bill59, pkl03, Ferrari55whoa and 2 others like this.
  3. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,667
    Argent/Brasil
    Guido
    Yes, skip that friend !!
  4. Bluebottle
    Bluebottle F1 Veteran
    8,530
    Newbury, Berkshire, England
    No, send him the bill.
    tritone and greg246 like this.
  5. belfry
    May 14, 2015
    486
    Robert Batt
    The alternators was working fine when I put the car away. I wonder if it's a coincidence.
    So, it's in with the new alternator next weekend I guess?
  6. fatbillybob
    Aug 10, 2002
    28,990
    socal
    #6 fatbillybob, Jun 29, 2025
    Jeepers routinely submerse alternator in water crossings. It shortens life but not an always failure. Alternator are water resistant taking splash of dirty rainwater and road puddles all the time. Few cars are covered like ferraris. It could have been coincidental death or you killed it with water. Before swapping out I would spray in electrical contact cleaner that helps to dry out and displace water. Soak it good. Let dry overnight. Charge battery to about 12.5v. Check on the meter when charger is off. Start car let it squeal and run for a bit. Put a meter to see if you get about 13.8 v output on the battery terminals while running. Maybe you get lucky. Image Unavailable, Please Login
  7. tazandjan
    39,164
    Agree with FBB and Brian. Bad idea, but let everything dry out before panicking.
    Ferrari55whoa likes this.
  8. belfry
    May 14, 2015
    486
    Robert Batt
    Thank you. I will try this next.
    I was surprised that a relatively small amount of water from my cleaning could kill an alternator. It is quite protected from above as the plastic covers look to protect from above and the sides.
    Where these alternators are unprotected is from below, where they seem to be entirely open to the elements. Certainly any decent puddles of water in the road after or during heavy rain would soak the alternator way more than my light cleaning of the engine bay (I avoided spraying water on the actual engine as much as possible.)
    I will try electrical contact cleaner today and report back.
  9. belfry
    May 14, 2015
    486
    Robert Batt
    Electrical contact cleaner made no difference, so I changed the alternator today and everything is working again. It was lucky that I had a spare on the shelf.
    Now to get the faulty one refurbished.
    fatbillybob, Qavion and Aerosurfer like this.
  10. cgt000
    cgt000 Formula Junior
    780
    Northeast
    Are you still friends with the "friend"?
