Front 84 308 brake hoses | FerrariChat
Discussion in '308/328' started by ckracing, Jul 5, 2013.
  1. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    I checked all 333 cross references. What other car uses the same front rubber brake hoses for a 84 308?
    thanks in advance.
    Charlie
  2. vp277
    vp277 Karting
    Mar 1, 2010
    101
    LI, NY
    I recently searched for brake hoses for my '85. The rears are easy to find, but there's nothing for the front except for Ferrari parts or custom stainless lines. Ended up buying the stainless set from superperformance. The fronts were about 1/2 shorter and the rears about 1 inch longer than the originals, but it works fine.
  3. Wilson308
    Wilson308 Formula Junior
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    I recently bought some Goodridge after months of searching and assuming they wouldn't fit based on negative threads about them, and they ended up fitting fine, almost exactly the same lengths as the original lines in my 84 Euro QV. Not sure what to tell you if you need rubber lines for concours, but the Goodridge stainless seem to be a good option otherwise.
  4. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    I got a full set of Goodridge G-Stop stainless hoses from Hoerr Racing through Amazon for $126. (front and rear lines) Fit great, easy to install. Brake pedal is much firmer with the new lines.
    Part number for Goodridge G-stop lines for a 308 is GS27001. You can alos find OEM style lines from Goodridge. Regular OEM style is PN SFE0200-4P or -4C
  5. thecarreaper
    thecarreaper F1 World Champ
    18,058
    Savannah
    Going to quote you for credit and add you to the cross ref thread I started. :) great post !
  6. ckracing
    May 20, 2006
    728
    Charles
    Thanks everyone for the help.
    Charlie
