Front Bonnet Electrical Problem | FerrariChat
Discussion in '360/430' started by Zenglo, Jun 7, 2020.
  1. Zenglo
    Zenglo Rookie
    Dec 23, 2019
    5
    Huntsville, Alabama
    Glen Wagner
    Hey guys.
    I've been racking my brain for a couple months now and my two brain cells are worn out.
    My 2005 360 Spider is sending a continuous unlock signal to the Front Bonnet opening actuator whenever the ignition is off and the doors are closed. If I open either door or turn the key to on the signal stops. So if I park and lock the car, the hood immediately unlatches and the alarm goes off. To make the car useable I've pulled the Bonnet opening actuator fuse and use the mechanical release,
    There's a microswitch located with the opening actuator but I'm pretty sure all it does is turn on the luggage compartment light and start a timer for the light. Any thoughts?
  2. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    Sounds like an electrical short, wear on the wiring harness. Time to start tracing and find out what is shorted.
  3. Zenglo
    Zenglo Rookie
    Dec 23, 2019
    5
    Huntsville, Alabama
    Glen Wagner
    I’m ready to do that, but why does it stop when a door is opened?
