Front bonnet foam seal | FerrariChat
Discussion in '206/246' started by Daryl, Apr 22, 2010.
  1. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,035
    Barrington Hills, IL
    Daryl Adams
    I need to replace the foam seal between the bonnet and radiator. Anyone have a good source?
  2. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    Dennis McCann had foam pieces that had to be trimmed to fit. I don't know if they still do.
    Regardless, I frankley think ANY piece of 2" x 2" by 3' piece of foam could be trimmed to fit and would be very cheap.
  3. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    #3 Crawler, Apr 22, 2010
    Lowe's and Home Depot sell a square-section foam plastic that comes in rolls. I don't want to go out to the garage now, but the cross section is almost identical to the factory stuff (maybe 3"). It even has a peel-off strip with adhesive on one side, and is very inexpensive. I think it's mainly intended to seal around window-mounted A/C units.
    I installed some about 4 years ago and it has held up perfectly. The worst part of the installation is scraping off what remains of the old, rotten foam rubber.
    The first thing I noticed after replacing the foam was that the engine ran cooler with it back in place. It serves the purpose of preventing the air from diverting over the top of the radiator and reducing its effectiveness.
    It you'd like, I can send a photo tomorrow, and also measure the dimensions. I can give you the exact length to cut.
  4. DinoLasse
    DinoLasse Formula Junior
    606
    Sweden
    Lars
    The item you want to look for is: Air Conditioner Weather Seal, 2 ¼” x 2 ¼” x 42”.
    The problem is that Lowe’s and Home Depot no longer carry that size. They only have the 1 ½” x 1 ½” strip and that is not enough to seal the gap. Believe me, I tried. The thicker seals are available online, though. I found mine at www.amconservationgroup.com. Item number P592. They are not the cheapest, but at $9.25 they are still reasonable, and they ship immediately. Here is the link:
    http://www.amconservationgroup.com/store/pc/showsearchresults.asp?pageStyle=&resultCnt=10&keyword=P592&submit.x=6&submit.y=12
    By the way, these seals no longer have the adhesive backing, so you need some contact glue or similar to attach it to the lid.
  5. rynoshark
    rynoshark Formula 3
    1,034
    Pacific Northwest
  6. 2GT
    2GT Formula 3
    Aug 25, 2008
    1,842
    Western NY
    Fred
    Believe it or not, my body guy sourced the correct foam at a fabric store and made me a few copies by trimming the foam with an electric carving knife! They look and fit great. Fred
  7. need4speed
    need4speed Formula 3
    Nov 3, 2003
    1,616
    Pacific Palisades
    Hi Guys,
    Is your foam applied to the top of the radiator or the bottom of the trunk/boot lid? I've always put mine on the top of the radiator. But my bodyshop put the new foam on the bottom of my trunk/boot lid. They are a concourse shop so should know their stuff. But I'm thinking in this case, it's wrong.
    Thanks for any info,
    Manny
  8. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Mine is on the lid and has been there forever...if that helps
  9. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    dignini,
    Thanks for the reply. I guess I had it wrong. :(
  10. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    The foam should be stuck to the underside of the lid. No doubt about that.
  11. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,035
    Daryl Adams
    Finally got around to chasing down the foam seal material and found it at Menards. Thanks guys.
  12. 500tr
    500tr Formula 3
    Feb 28, 2004
    1,218
    Germany
    Volkmar Spielmann
    Correct!
  13. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
    Bought this from Lowe's for less than $4. Didn't have to order it.
    Freeman
  14. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,035
    Daryl Adams
    Menards price was $2.99.
  15. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
    My kind of guy!
